CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Whats your battery life when not driving??
Old Apr 24, 2014 | 08:19 PM
bimerbenzbently's Avatar
CL55 AMG/S55 AMG
Im wondering how long does your battery last when you park your CLs.
I noticed if i park my car in the garage it will not start after a week of sitting. I have to charge the battery than everything goes back to normal. This dosen't seem normal and I'm curious if this happens to anyone else. This gets annoying since you need to break into the trunk and force it open to access the battery.
if i start the car daily the battery never dies so keeping that in mind there must be something draining my battery or it could be time for a new battery.
any help is appreciated
thanks
Old Apr 26, 2014 | 08:52 AM
TwinTurboTim's Avatar
2006 CL65
Maybe you should test your battery. Probably just getting weak.
Old Apr 27, 2014 | 12:53 PM
CL55 AMG/S55 AMG
will do
thanks
Old Apr 27, 2014 | 01:33 PM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Do you have a lowering module?
Old Apr 27, 2014 | 01:39 PM
CL55 AMG/S55 AMG
i lowered it via the Mercedes Star program
Old Apr 27, 2014 | 01:50 PM
OCKlasse's Avatar
MBworld Guru
Nevermind then. The V2 in particular draws a lot of power.
Old Apr 27, 2014 | 02:02 PM
Rdub's Avatar
14 GLK 250 BT
The short answer: buy and deploy a battery trickle charger.
The oem charging systems are NOT designed to bring the battery back to 100%. Further it is wishful thinking that our cars LOADED with electronic do dah's (being a technical term) do/will not draw current when OFF. This does not even take into account further custom electronics, or individual "customized" current draw !!
Old Apr 27, 2014 | 03:33 PM
Blkvip's Avatar
12' E559
mine alllllllllmost didn't start after a week or so of sitting, buddy who used to own a CL had same problem. we both run V2 lowering mod's.
Old Apr 28, 2014 | 12:01 PM
CL55 AMG/S55 AMG
your right, i been using a trickle charger
i just thought the battery should last without any help
what battery are guy guys running? is there a specific one i should get i was thinking to replace my battery just incase plus its already almost 2 years old.
thanks for all the help by the way
Old Apr 28, 2014 | 02:35 PM
Rdub's Avatar
14 GLK 250 BT
Unless you have a bad cell (normally statistically rare); with the trickle charger, it would not be unreasonable to expect a minimum of 4 years. Most of mine are diesel so I would normally recommend OEM (specified for greater current draw) . In the gasser case, still oem, but you have a greater latitude.
Old Apr 29, 2014 | 04:37 PM
MagCL's Avatar
CL55, S550, 450SL
If you have an original MB battery you should get at least 5 years out of it. I would buy a CTEK maintainer, charge it up completely and then disconnect it. If the car won't start again after a week of sitting, then you have something draining the battery. I had the same problem with my CL and it turns out there was something wrong with the heated mirror and it was draining the battery.
Would you be able to share how you lowered the car using star?? I tried once, but failed.
Old Apr 29, 2014 | 05:49 PM
Dr Matt's Avatar
05 CL65
Buy an Odyessy (not optima) battery when you replace yours. Not cheap, but why would you go cheap on a battery for a. CL.
Old Apr 29, 2014 | 09:20 PM
CL55 AMG/S55 AMG
thanks for the advice
and about the lowering, i actually took it to one of my buddies that owns the Mercedes Star program (he is also a member on this forum) and together we took our time and dropped it. I use the "raise" button when going over speed bumps or whenever its needed since I'm riding pretty low.
I will look into the Odyessy as my next battery, hopefully i can find it in Canada
Old Apr 30, 2014 | 03:23 AM
benz_addict's Avatar
V12TT
I think it needs to be the AGM battery I know they sell it at crappy tire for $199 if you need more help call me tomorrow !
Old Apr 30, 2014 | 12:39 PM
CL55 AMG/S55 AMG
respect fam
Old May 1, 2014 | 10:06 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I heard if you lock the doors, power will be reduced while sitting up.. I use a MB bat and can sit for a month, with no issues. I usually drive the car once a week though.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old May 1, 2014 | 01:52 PM
CL55 AMG/S55 AMG
thanks for the tip
just wondering how much do the MB batteries go for and is there a real advantage besides the name brand
