CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Gutted Cats or Downpipes
Old Aug 28, 2014 | 01:10 PM
V12Godspeed's Avatar
Your worst nightmare...
I am thinking of either removing the cats completely or Gutting them internally and leaving them in place. What are people doing these days? Thanx
Old Aug 28, 2014 | 03:05 PM
V12TTenthusiast's Avatar
06 SL65AMG, 13 Tesla Model S 60kwh, 02 Jaguar S-Type 3.0, 12 S550 4 Matic, 07 E320 Bluetec, 06 LX470
I got 3 Inch Catless on mine, but my whole exhaust is custom made 3 inch all the way around
Old Aug 28, 2014 | 03:45 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
cut the cats out and weld a 3" pipe in place with 02 bungs
Old Aug 28, 2014 | 04:52 PM
RaceHorse's Avatar
CL65
This above, or downpipes... Ask yourself, "will there be a time and place where they are needed for emissions?" I'd find a decent exhaust place and have downpipes made in house. I think its difficult for real accurate fitment without the car on site. In the end the price will be about the same. Also, you will need to ditch the stock airboxes if you already haven't. My car ran out of breath in the higher RPMs, spitting out the exhaust faster than it could draw air in. While you are at it, are you going to remove the flat spot towards the back where the support is located? I kinda wish I had, I'm sure its not a big difference, but it just looks bad after everything else is nice and big.
Old Aug 28, 2014 | 04:55 PM
Yep, got an intake system. Once engine goes down, will do the downpipes as well. Thx
Old Sep 3, 2014 | 02:13 PM
Can someone suggest a simulator or any kind of trickery to trick the CEL? I will get tuned once everything is done. Thx
Old Sep 3, 2014 | 02:15 PM
I used those 90 degree elbow 02 simulators off vivid racing, did the trick
Old Sep 3, 2014 | 02:17 PM
Dr Matt's Avatar
05 CL65
Tuner should be able to turn off rear O2's in the tune. Not a good idea to drive around with all the mods you have planned without a tune so just have them do that in the initial tune.
Old Sep 3, 2014 | 02:21 PM
She will get tuned for sure, Thx
Great Thanks.
Old Sep 3, 2014 | 02:23 PM
Taking it off tune isn't 100%, I had Jerry do mine and it still popped up time to time, to get rid of it for sure I had to do those 02 simulators to top of what Jerry did in the tune
Old Sep 3, 2014 | 02:25 PM
Do you have the link? Cant seem to find it. Thx
Old Sep 3, 2014 | 02:31 PM
My bad it wasn't vivid racing it was summit racing this is the link
http://www.summitracing.com/parts/vp...FQQT7Aodr1gARw
Old Sep 3, 2014 | 02:36 PM
Thanks a lot.
Old Sep 3, 2014 | 02:37 PM
You'll prob need to get 2 of them 1 for each side and when you use the washers, I think I used the middle size of the set of 3
Old Sep 3, 2014 | 04:34 PM
RaceHorse's Avatar
CL65
I have the 90's also. I have NOT had the tune adjusted for the 02s running without the cats. Under normal hard pulls the light doesn't go on. If I do a long highway pull I will get the CEL even with the elbows. It happened even easier with the stock air boxes. If You haven't done anything yet I'd consider having an extra bung welded in place for data logging.
Old Sep 3, 2014 | 04:41 PM
Thanks. Yes, will be putting in an A/F logger.
Old Oct 30, 2014 | 03:37 AM
adamls2's Avatar
W215 CL65
Does anyone have the speeddriven cat-less downpipes, or any other cat-less setup for that matter? I'm very curious to hear the sound difference vs stock. Really want to pair this with my muffler delete. Would appreciate any input!
Old Oct 30, 2014 | 09:30 AM
eaks's Avatar
2005 CL65
I have the speed driven catless downpipes and am super happy with them. I originally told the shop to cut my mufflers off but they called me after they had the downpipes on and said they would recommend keeping them on as it really changed the sound already. I went and fired it up and love the sound with my mufflers still on.. Sounds deadly at startup, a nice rumble at idle and when you get into it it sounds great and the best part is there is no drone at highway speeds..
Old Oct 30, 2014 | 10:06 AM
shardul's Avatar
i have catless setup with no muffler and it is real loud. I plan on putting the mufflers back on
Old Oct 30, 2014 | 09:46 PM
adamls2's Avatar
W215 CL65
Thanks for the input guys. I'm assuming the catless dp is similar to the muffler delete effect.
Shardul, i'd love to hear a sound clip or something! It's hard for me to have too loud of a setup, haha. How loud would you say it is insude the car, compared to just the muffler delete? ( if you had it like that before the catless)
Thanks!
Old Oct 31, 2014 | 04:41 AM
RaceHorse's Avatar
CL65
I think the hard part is exhaust mods on the V12TT just make it a little louder without any change in tone. Sound clips don't do any justice it needs to be heard/experienced in person. Its a smoother firing pattern than a V8 so you won't get the same throaty sound that you hear from a V8 with an exhaust. That's a huge part of the appeal to me. These cars are very unassuming, silent killers to many cars on the road.
