CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Headers, Throttle Bodys & Camshafts
Old Mar 4, 2015 | 08:39 PM
rbreaks's Avatar
'06 CL55 AMG, '08 SL65 AMG, '09 e550 4Matic, '13 Range Rover Sport Autobiography
I had specific questions regarding headers, throttle body and camshafts. Let me preface that I have done many mods to my CL55, but I am still very much of a newbie and learning every step of the way. I don't race the car, just love modding it and having something powerful and unique. In addition to the mods already in my signature, I'm looking next into:
1) Headers
Kleemann mid range headers (+40bhp)
2)Throttle Body
Kleemann 80mm (+30bhp)
3) Camshaft
Kleemann (+15bhp, beneficial above 4k RPM)
The above was recommended, along w/ the estimated power gains to expect.
Headers
  • Forgetting about cost, which header would you suggest and why?
  • Why do you think I was recommended mid length vs. long?
Throttle Body
  • What exactly does a throttle body do?
  • Is there a difference in 80mm vs.82mm in terms of performance as I saw that Renntech has one as well?
  • Forgetting about costs, what are the recs for which type (short, mid, long, etc.) and brand (MBH, Renntech, etc.) throttle body to use and why?
  • Will I still be able to keep/use my Renntech CF airbox with a larger throttle body?
Camshaft
  • No idea what these do and what the options are?
Thanks in advance for sharing your knowledge and experience.
Old Mar 5, 2015 | 11:00 AM
Andy0331's Avatar
'08 CL63
I had Kleemann cams on my E55, I was happy with them. Although they don't add tons of hp, they change the dynamics a bit. They cut a little low end torque (not really a problem IMO) and allow the car to pull longer into higher rpms.
They change the idle lope a bit, but no surging and it certainly doesn't sound wild.
Old Mar 5, 2015 | 04:27 PM
rbreaks's Avatar
So should the Cams be the last thing to play w/ or at all?
Old Mar 6, 2015 | 09:05 AM
Andy0331's Avatar
'08 CL63
The common opinion is that cams are done last. You would certainly do the headers first; no discussion there.
Old Mar 6, 2015 | 09:13 PM
rbreaks's Avatar
Any thought on MBH vs. Kleemann?
What about throttle body?
Old Mar 7, 2015 | 09:15 AM
Andy0331's Avatar
'08 CL63
MBH vs. Kleeemann? I had Kleemann's on mine, but that was long before there were so many other options. I had no complaints, but I think full long tube headers is the way to go.
Throttle bodies will all be about the same (another Bosch TB of a larger diameter). IIRC, Kleemann did an 80mm & Renntech had a 82mm, but I can't really remember off the top of my head. No real difference in quality among any of the manufacturers.
Old Mar 7, 2015 | 02:34 PM
principledchiro's Avatar
2006 CL55 AMG
Mods
Our 06 CL55's are twins. Last month on went: Eurocharged (EC) blower pulley, EC tune, EC I/C, Bosche 10 I/C pump, Beltwrap kit, and K&N airfilters. To say beastly is almost an understatement: Estimating + or - 560 chp. Next: EC midlength headers and Quiafe LSD. Not too sure about adding a 80 or 82 mm TB. When to swap in 550 injectors and if to separate the engine and I/C cooling.
Old Mar 7, 2015 | 04:24 PM
rbreaks's Avatar
I think I'm leaning towards MBH for LTH, but really want more feedback from people who have direct experience.
I'm still unsure about throttle body, who to use?
Old Mar 10, 2015 | 09:26 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I would add long tubes and get the most power out of the exhaust. Booasted webngines love free flowing exhaust. Cams are not a good bang for the buck on our engines. Just my opionion based on the limited lift, duration, HD valve springs and the tight lobe seperation offered on them.
Add LT`s, smaller upper pulley , 3000 stall and you will have "insane mode" going on!
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
