question about alternator amperage
thanks for your input.
Nick
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
thanks
If the 150 amp alternator is water-cooled and is form, fit and function interchangeable, I would say interchange it!
People sometimes get a bit obsessive about using exactly the right parts and consumables. My "proper" battery went flat when I left the lights on at work, but I still got a jump start from a MINI! That has a tiny battery, but it started fine. I bought a used but good BMW 530D battery, and have zero issues. I wouldn't cut corners with fluids and filters, but I happily use commercial standard ABC hoses and Korean tyres. Some details aren't worth worrying about too much.
The main thing with electrics is try to keep the battery between 12.4V and 14.4V at all times to maintain the chemistry and avoid damage, and never let it go below 12.0V. Fully charged is 12.6 to 12.7V, depending on temperature, and with the engine running, the charging voltage wil be 13.2V to 14.4V. It doesn't take a huge charging current to achieve 14.4V - certainly much less than 150 amps! Depending on the capacity and condition of the battery, it will be more like a tenth of that.
So for our cars, 180 amps is a bit overkill for the sake of standardization (while the Maybach was still in production). Good overkill though, as it probably reduces the risk of the rectifiers and regulators overheating, so it will probably improve reliability in that oven of an engine compartment.
Nick
PS. Just remembered - I thought our cars used 210 amp alternators? Maybe there are various standards depending on market? Nothing much to worry about though - our alternators are still more powerful than anyone else's starter motors!
