CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Finally going to go bigger turbos on my CL65
Old Aug 10, 2016 | 09:58 PM
TwinTurboTim's Avatar
2006 CL65
I have wanted to go bigger turbos for a while but have just been finishing up 2 other cars that I own so now that these 2 cars are done its ready to get this thing going. I been kinda watching the problems that Speeddriven has had and it seems like mostly trans problems so that seems like an easily fix problem. I see they made log style manifold and I am going to try something different. I ordered some manifolds from a 2002 CL600. These are non turbo manifolds. They come as 4 three cylinder manifolds. My idea was to run twin scroll GTX3076's or GTX3582's. My main goals are keeping as much tq as stockers had with as early spool as stockers. I would just make a y pipe from the 2 manifold to the turbo. I like the idea of running the stock manifolds because they will retain a lot more heat then even schedule 40 tubing with retain. Im not sure how I am going to fit 4 wastegates but we will see how things look as I will pull the motor soon. Right now I am just logging the tune I have now and in a week or so I am going to get it running on E85 with bigger injectors. Once I got my fuel system all dialed in I will change the turbos over. Hopefully all goes well!
Old Aug 10, 2016 | 10:18 PM
Dr Matt's Avatar
05 CL65
Nice. Going to follow this thread for sure!
Old Aug 10, 2016 | 10:55 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Keep us updated and make more than one set of turbo manifolds.
Old Aug 11, 2016 | 02:51 PM
BlownV8's Avatar
Do the 3 valve M275 heads have the same exhaust spacing and fastener locations as the 4 valve M120 V12?
Old Aug 11, 2016 | 03:19 PM
2006 CL65
I wouldnt think they do.
Old Aug 11, 2016 | 03:23 PM
2006 CL65
That is why I got them from an 2002 CL600
Old Aug 11, 2016 | 10:16 PM
BlownV8's Avatar
Does the M137 have the same heads as the M275?
Old Aug 12, 2016 | 08:07 AM
1ForcedBenz's Avatar
Benz
Essential yes.
Old Aug 12, 2016 | 08:49 AM
BlownV8's Avatar
Who is doing the tuning. Should be a monster.
Old Aug 12, 2016 | 12:14 PM
Benz
And to the OP, I'm truly not trying to be the downer here but with multiple first hand experiences on these engines and space available your idea isn't going to be plausible. Your going to have to build a manifold that will nearly mimic Speedrivens if you even want to have a shot at this working out.
The area you have available to fit what your talking about doesn't exist. There's undeniably a reason why I know more then a few people over the past decade that have pulled there motors and tried to make this come to fruition "myself included". It's doable but not with standard housing turbo flanges and definitely not with externally gated turbo let alone 4 waste gates.
Now if you want to go top mount you have a lot more freedom but then every aspect of stock appearance is gone plus then the need to reroute lots of other items.
Basically what I've come to find out is this project is not easily completed. And without using specially built/ordered turbos with the certain flanges/ internal gates / and cooling your likely going to hit the wall so to speak. And even with all those components its still going to take some trail and error. But if I was half as good of a fabricator as I wished I was id be doing it honestly.
Old Aug 12, 2016 | 12:29 PM
2006 CL65
We have been all talking about this at the shop and we do agree there isnt much room but I think if we mount the turbos far enough back there will be enough room. I have also been thinking about scrapping the garret idea and going with Precision 6262's as they are a ton smaller or even the smaller internal wastegated turbos from precision. I will let ya know more as we progress. I just dont think any more can be had from the stock turbos because the hotside is just not able to flow anything more.
Old Aug 12, 2016 | 04:22 PM
Benz
Yeah I remember making a mold of the spacing on either side of the engine to strut towers, sub frame, motor mount bracket, and steering shaft and I kid you not there's only about a 1/2 max to go vertically and horizontally and that leaves no margin for engine torque which would put the turbos into the body.
At the time and currently I still believe if you make a custom fab'd metal motor mount bracket frame work you can add so much needed but will still need quite a bit more to work with.
The reason my project hit the wall was Tial at the time was the only manufacturer I could find who had an internally gated turbo with the flanges and setup I wanted to use but were literally not doing a production run until an order of 15+ were made at $3500 each. You can make it happen that I know but it will undoubtedly take a 100% custom log style manifold and an internally gated turbo, period. IMO
And there's 0 denying the stock manifolds are no good for making anymore power then a tune can provide. The hot side is choked up even with a bigger hot side on the factory units milled into the manifolds. The drive pressure exceeds 2:1 closer to 3:1 even on tuned cars.
Old Sep 3, 2016 | 11:56 PM
precisionfab's Avatar
plenty
I'm not all too close (CT), but if you're interested in someone that's familiar with turbo systems to build you a proper setup, let me know. I would stay away from Precision, far away... You don't need schedule 40 tubing, not even schedule 10... and you certainly don't need 4 waste gates. If you'd like to talk, message me first 8608979983
Old Sep 5, 2016 | 07:50 PM
320 dreamer's Avatar
2003 porsche 996 turbo
look at the borg warner 7163 turbos. bov and internally wastegated to 35 psi capable of 1000 hp on e85. small compact and spool like krazy! its what i use on my porsche
Old Sep 7, 2016 | 08:52 PM
RoadHazard's Avatar
Speedriven CL600 V12TT
Hell yeah! If anyone can pull through with some crazy turbo piping it's you. Is a rear mount turbo an option? If the m137 headers bolt right in, you could fab up some of those Technical Garage Sasaki equal length headers and mount turbos in the rear. A little more turbo lag vs way lower temps overall makes sense to me.
Old Sep 7, 2016 | 09:18 PM
2006 CL65
Yeah I did check out those turbos. Thanks for the heads up! They do look like a great turbo and they can do V band flanges too!
Old Sep 7, 2016 | 09:20 PM
2006 CL65
Yeah I thought about mounting the coolant/washer tank to rear and doing a big single there. Also thought about moving ABS module and ABS tank to rear and doing big twins there. We will see what happens as I go.
Old Sep 7, 2016 | 09:29 PM
2006 CL65
The fact that you wouldnt even use SCH 10 tubing makes me cringe!!
Here is the manifold on my 87 300SDL. It has a 2000 OM606 swapped in. Let me know if you think I am up to the task? I have many other cars I can show you if you need more credit to my ability to get stuff done.
https://*******/photos/yYhDvV2VsscSZRAq8
https://*******/photos/ai6ZTULSYPrkdoNx8
Attached Thumbnails Finally going to go bigger turbos on my CL65-20150612_183623.jpg   Finally going to go bigger turbos on my CL65-20150612_225350.jpg
Last edited by TwinTurboTim; Sep 7, 2016 at 09:37 PM. Reason: Wont let me post links
Old Sep 7, 2016 | 09:30 PM
plenty
lol why would you need to use schedule 10. Show me a car that makes real power that uses schedule 10 turbo headers.
Old Sep 7, 2016 | 09:33 PM
plenty
BTW the links don't come up
Old Sep 7, 2016 | 09:34 PM
2006 CL65
I know I am trying to figure out how to post them....
Old Sep 7, 2016 | 09:37 PM
plenty
1400rwhp in the works here. no schedule 10
Old Sep 7, 2016 | 09:41 PM
2006 CL65
https://www.facebook.com/turbotimsanythingautomotive/videos/a.10205734089986439.1073741830.1681418401/10205734091506477/?type=2&theater&notif_t=video_processed&notif_id=1473299238237323https://*******/photos/yN8mCoVdWpMefVpf9
This is my Volvo. These manifolds are made of ****ty tubing and it flexes 1/4 inch if you press on it.
EDIT....Whe does this site not let me share google photos or videos?
Old Sep 7, 2016 | 09:48 PM
2006 CL65
Old Sep 7, 2016 | 10:26 PM
plenty
nice man
