CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL55 AMG Trunk wont close please help
Old Aug 7, 2017 | 03:52 AM
Amgfan80's Avatar
2003 cl 55 amg
I have a 2003 CL55 AMG and the trunk will open fine with remote key but the red button is now not lit and when I press it the trunk dose not close . there is a green flashing button inside the upper part of the trunk lid when open I pressed it but nothing. I have to close the trunk now with my hand any tips or advice on how to fix this thanks
Old Aug 7, 2017 | 11:31 AM
Geraldius's Avatar
'15 GLK350, '05 CL65 AMG, '04 C320 4matic
The green flashing button is an emergency inside trunk release switch. Doesn't do anything when the trunk is already open.
The trunk closes by means of a hydraulic cylinder and pump. The hydraulic pump is controlled through the PSE (vacuum) pump circuitry. Are there any other systems that the vacuum pump operates that are also malfunctioning, for example door locks, seat lumbar support, etc?
You might try resetting the PSE pump controller by temporarily pulling fuse F62 for a minute or so and then reinserting it.
Old Aug 7, 2017 | 01:42 PM
Amgfan80's Avatar
2003 cl 55 amg
ok where exact is the F62 fuse located? no all other functions are working properly . just the red buttion is not lighting up so maybe it is the fuse
Old Aug 7, 2017 | 01:53 PM
Geraldius's Avatar
It's behind a cover below the front of the right-rear seat. This fuse would not be bad if all the other functions are still working. However removing it forces the controller in the vacuum pump to reset and clear any error state it may have set itself to.
Old Aug 15, 2017 | 02:44 PM
Amgfan80's Avatar
2003 cl 55 amg
I don't see a fuse that says F62 I provided a pic of the fuses let me know witch one it is to pull out to reset the trunk hydrolic pump
Old Aug 15, 2017 | 02:49 PM
Amgfan80's Avatar
2003 cl 55 amg
https://mbworld.org/forums/attachmen...stc=1&d=150282 here is the link let me know whatfuse it is thanks
Attached Thumbnails CL55 AMG Trunk wont close please help-20170815_100923-1-.jpg
Old Aug 15, 2017 | 08:59 PM
Geraldius's Avatar
It is the yellow 20A fuse, 5th one in from the right side, (or 6th if you count the missing one where there is a space).
Old Aug 16, 2017 | 06:44 PM
Amgfan80's Avatar
2003 cl 55 amg
I tried pulling the 20 A fuse but I reinserted it after like 20 seconds should retry it again? or is there another problem with the trunk?
Old Aug 16, 2017 | 06:54 PM
Amgfan80's Avatar
2003 cl 55 amg
also the trunk light is not working so could it be another fuse ?
Old Aug 17, 2017 | 11:04 AM
Geraldius's Avatar
That was really the only easy DIY fix. If it's still not working the problem is deeper. You're going to need a specialist to diagnose it in person.
