CL65 stock 1/4 mile
I am having issues launching and looking for advice from the experts. If I leave soft, I run 1.77 60 foot, but if I leave hard, it spins bad and runs a tenth slower. My best ET was 11.66 running a Mickey Thompson ET Street R 275/40R17. DA was 1100ft. I am heating the tires a lot, but after getting some feedback after racing, it seems traction control is fighting me. I am going to try dyno mode next time to see if I can get more heat in the tires.
I guess my main question is, what is the best number I can expect for a showroom stock CL65 with a sticky tire?
Tonight results, Dyno Mode was worse as it would only spin the right tire in the burnout box. Then the left tire would not hook. I'm kinda frustrated with it right now, but even at that, I had a good time.
I did get to race a ZL1 Camaro - which is one car I have wanted to race. I beat him the first time. He came up and asked for a rematch. Second time it was dead even across the finish and I had to look at the time slip to see what happened. I ran a faster ET, but he won with a better reaction time.
Good times!
One wheel peel.
If I recall, Dr. Matt had issues with his Quaffie. That has me less than excited about blowing that amount of money on one. I have been considering building a third member to replace the stock chunk.
My son keeps recommending jb weld locker and assures me he can work miracles. He's no help. Lol
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
I have got the howling sound with the open diff a few times but when it's only spinning 1 tire. Extra water was helpful. On a burnout with less water, I ended up snapping my pinion gear once. Now line lock and extra water makes me feel a little safer, but there is always a risk with sticky tires.
I'm probably going to take a break from the track for a bit. My son wants to play too, so we will be taking his truck next time. He needs to learn the tree with something slower than the CL65. lol
