CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Check Engine Light - 02 Sensor
Old Oct 7, 2004 | 10:16 PM
awiner's Avatar
2003 CL55 AMG
Got a Check Engine Light today. Pull the codes with my scanner and it flags a Oxygen Sensor Bank 2 Sensor 2 no data code.
Stay tuned for the fix.
Old Oct 8, 2004 | 02:12 PM
awiner's Avatar
2003 CL55 AMG
Before I started the car this morning I cleared the MIL codes and turned off the Check Engine Light. Started the car and all o2 sensors were registereing and acting normal per my scanner. I used the scanner all the way to work. No problems, no CEL from MIL's...
Maybe it was a computer malfunction... Maybe it will re occur sometime.
For now, all is well.
Old Oct 8, 2004 | 11:38 PM
JamE55's Avatar
Out Of Control!
Hey Adam
Where'd you get that scanner you are using to detect those codes? Sounds pretty handy. What else will that scanner do besides read codes and diagnose them?
Old Oct 9, 2004 | 12:37 AM
awiner's Avatar
2003 CL55 AMG
I use the Nology PDA Dyno Scan and Scanner software with my Sony Clie PDA.
Does a lot of cool stuff:
http://www.nology.com/pdadyno.html
Old Oct 9, 2004 | 05:56 PM
m258's Avatar
2001 CL500
Wink :)
ooooooo......that's noice.........
ima look into that one.....
Old Oct 12, 2004 | 03:03 PM
awiner's Avatar
2003 CL55 AMG
Another code got thrown today. P0410 .. Secondary Air Pump.
As far as I can tell the Air Pump is working, so I'm now seeing if a vacuum leak is the problem. The code only has thrown 2 times in the past week. So, this is weird.
Old Oct 17, 2004 | 11:23 AM
Sam 325i's Avatar
Turbo Diesel
Adam Can i ask what you do?
The reason I ask is I was just skipping through the channels and there was a guy on VH1 named Adam Winer. It said Editor of some magazine, was that you or just the old same'd name'd trick?
Old Oct 17, 2004 | 01:55 PM
awiner's Avatar
2003 CL55 AMG
Not me. I think the editor of FHM is named Adam Winer though.
Old Oct 30, 2004 | 09:46 PM
awiner's Avatar
2003 CL55 AMG
Problem fixed. Ended up being a faulty relay that controls the Air Pump.
Old Nov 20, 2004 | 05:13 PM
mike salvato's Avatar
check engine" light retrieve code-1993,300E
Hello, I'd like to buy a code reader/scanner for my '93 300E but I'm not able to locate one. Can anyone help?
Old Nov 20, 2004 | 06:44 PM
awiner's Avatar
2003 CL55 AMG
Most of us are using OBDII readers. OBDII started with cars 1996 and newer.
For a '93, I am not sure what your options are.
Old Dec 29, 2006 | 02:09 AM
mycbr1000rr's Avatar
please help with check engine light on
Problem fixed. Ended up being a faulty relay that controls the Air Pump...
what relay is that, what's the part number, how much is it? where's does it located? can i do it myself?
i have a code for secondary injector, but the car runs fine just the check engine light is annoying..do i have the same problem as you?
i have to disconnect the battery everytime the check engine on came on..after i disconnect it it fine..
Old Dec 29, 2006 | 11:38 AM
awiner's Avatar
2003 CL55 AMG
It may be the relay, however, it also can be your air pump. DO you hear the air pump when you start the car at all ?
What year is your CL ? Did it need to have the recall for the airpump relay this past year ?
Old Dec 29, 2006 | 05:29 PM
I Have A 2001 S430 ...how Do I Tell If The AIR Pump Is Working Or Not?
