Buyers advice on CL63
considering this what should I look out for is it enough for me to inspect the body panels, suspension, fluids and run a full diagnostic scan myself? Or should I plan to stay a few days in the city (adding to the cost) to get a PPI just to possibly not but the car?
This is the type of car I’m willing to keep forever so all the other stuff that tends to go wrong I’m open to hear about too
Let me clarify I have only put 28k miles on it since ive owned it. Its only used for weekends.
1. Driver rear window stopped going up and had to replace regulator. Almost the whole rear interior has to come out to get the panel out.
2. Power trunk stopped working and had to replace pump and lines to make it work again
3. Valve cover gaskets leaking. Had to replace those
4. Front timing Cover seals all failed causing oil to leak over front of engine. Everytime I would move the car there was a small puddle of oil. Had to replace all cam sensors
5. ABC pump failed and came out to car to see large puddle of steering fluid o the ground. Had to replace pump and lines.
6. 2 years later all 4 shock were severely leaking. So bad that all 4 shock were covered in oil. Had to replace.
7. Loud tapping sound on cold start. The infamous Camshaft Gear issue. Had to replace those and all the lifters
Other that that.......love the car. I've never had a repair that was less than 5k.......NEVER. Each one of the listed items above was minimal that cost out of pocket. You dont want to know what the shocks job was. I could have bought another car for the cost of that work,
My advice is to be aware that these cars are beautiful to look at and drive amazing........but the are far from BASIC if repairs come.....and they will.
The only reason I've done all this....is literally because......it is my cream car.
i've got 3 other cars but I just love this one.
It is a dream car and I’m more than willing to dig into it and get dirty in order to keep it going. It will be a toy/weekend car and garage kept. I have two other MBs both significantly simpler tho (w201&w211) that I do 80% of the work on myself. These are the three cars I plan to own the rest of my life. I love many cars but have no interest in actually owning most of them
This car is more a gift to myself and i wouldn’t be relying on it as a daily at all. I honestly cannot afford a 5k repair and even if I could I’m the type of person that would refuse to pay it lol. I can stash it away in a garage since I have enough time, patience, and a couple experienced friends to help. But lmk if that is unrealistic for a car this advanced?
How have your motor mounts and suspension joints held up? Were most of those costs labor as well or did you diy whatever you could?
The ones I’m interested in buying are between 70K-100k miles and typically $15k-$20k. I just turned 30 and this will be my first V8!!
I've bought and driven as far as 9 hours home. I know of others who have driven farther.
No I wouldn't consider them DIY cars without buying enough tools, computers and software that you might as well find a good independent mechanic. But if you can't afford for $5k or $10k to leave your account at a moment's notice, I would say buy a simpler car.
GL
maw
EDIT... I bought my S55 when I was about your age... actually all of them... good thing I could afford the bills though because they definitely showed up in plentiful supply... expensive parts are what make the cars what they are.
I actually also had to replace both engine mounts and the trans mount. The engine ones were leaking(they are hydro filled)
I was a mechanic for years....eventually switching up to sales repair. I'm 46yrs old and just dont have the time or the willingness to do the work myself. I have a local Benz specialty shop I bring the car to if anything goes bad.
I use to drag race cars back in the day and have built multiple american muscle cars for people, but getting down to doing a strut job on a W216 is a......excuse my language.....*** NIGHTMARE!!
So....I drop it off and pick it up lol.......
I'm being completely honest when I tell you this car is not budget friendly. Just be ready. Nothing is a cheap fix on this car.
Motor and trans mounts
Valve cover gaskets
PCV valve
Oil filter housing gasket
Belt tensioners
Shock gaiters
Rear window control module
Brakes
ABC accumulators
Front suspension links
Rear Battery
It can be a DIY car if you have a good metric tool setup and a decent jack and stands.
I did want an AMG but I think this car fills most of what I was looking for for about half the price. I should have it before the weekend
Valve cover gaskets
PCV valve
Belt tensioners
Shock gaiters
Brakes
ABC accumulators
Rear Battery
Any tips to protect the ABC suspension, engine, etc while in storage? And any immediate service or preventative tips?
i know this is the AMG forum but thought I’d ask since this is started already
ABC is/was dialed on these, it's less dramatic than the W220's of old.
I would just keep 5k in the back pocket at all times and get familiar with how to order MB Genuine parts from the grey market sites online.
If you want something a little easier to live with, a 221 S63 sedan on airmatic is an option.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
