CLA 35, CLA 45 AMG (C117, C118) 2013 to Present, Two generations
Willall intake
Old Sep 16, 2014 | 02:06 AM
Rjs09gtr's Avatar
2014 CLA 45 AMG
Willall intake
Just installed the Willall Racing air inlet kit. It is a GREAT mod! Drastically improved the sound of the turbo spooling up, and even gives a slight blow off valve sound also! Throttle response and power are noticeable differences as well. Martin from Willall provided me with excellent customer service, and I'd recommend him and the inlet kit as a must have! Here are some pics of the difference between stock and the Willall kit
Old Sep 16, 2014 | 06:33 AM
CLA45AMG2.0's Avatar
cla 45 amg
how much did you pay
Old Sep 17, 2014 | 01:34 AM
cla 45 amg
i just thoguht about this, but can't you just widen out the stock inlets hole? starting a thread.
Old Sep 20, 2014 | 04:36 AM
Ezec63's Avatar
C63 Coupe
That piece is Cnc machined to an exact measurement Down to hundredths of a mm to be able to fit snug with the custom sized filter. See how the filter opening is bigger to match the size of the new "restrictor"? You can dremel it out but you won't get a perfect fit like that and would likely have air leaks not something I'd try on 60+K car
Old Sep 25, 2014 | 10:55 PM
dtc100's Avatar
CLA45 AMG
I think it is possible to dremel out the restrictor smoothly, but I don't think you can find a twist-on filter to match the enlarged intake.
Most aftermarket filters are clamp-on, not twist-on.
Old Sep 25, 2014 | 11:16 PM
ddtung's Avatar
Mercedes C200 CGI, CLS350, CLA45 AMG, AMG GTS(ordered)
Here are the specs on the K&N filter used:
Universal Air Cleaner Assembly
Round Tapered
OD-4.5 in./6 in.
Flange L-5/8 in.
Inside Flange 4 in.
Centered
Rubber End
Filter Length 7 in.
It may be possible to fit this to a modified and enlarged stock restrictor.
Old Sep 26, 2014 | 12:54 AM
cla 45 amg
Round Tapered
OD-4.5 in./6 in.
Flange L-5/8 in.
Inside Flange 4 in.
Centered
Rubber End
Filter Length 7 in.
Were onto our own DIY company bro! hahaha
Old Sep 26, 2014 | 03:40 AM
dtc100's Avatar
CLA45 AMG
Round Tapered
OD-4.5 in./6 in.
Flange L-5/8 in.
Inside Flange 4 in.
Centered
Rubber End
Filter Length 7 in.
Are you sure? Can you find the same specs but a dry filter? I don't think it is necessary to get an oiled one.
Did you find out how much is the OEM restrictor?
Depend on the cost, I might order both and play with them to find out.
Old Sep 26, 2014 | 07:37 AM
ddtung's Avatar
Yes I am sure.
Check the price of the OEM restrictor with your MB parts dept.
Old Sep 26, 2014 | 10:41 AM
Sincity's Avatar
I suppose a machine shop could widen it for you?
Old Sep 26, 2014 | 01:07 PM
tekfoc's Avatar
Veteran: Army
18 E63S
get to work .
http://www.verociousmotorsports.com/Shop-by-Category
Old Sep 26, 2014 | 03:12 PM
dtc100's Avatar
CLA45 AMG
Yes I am sure.
Anyone has the part #?
Old Sep 26, 2014 | 04:14 PM
dtc100's Avatar
CLA45 AMG
Ok I called the dealer, the inlet restrictor is part of the air box assembly not sold separately. The cost is $250.
At this cost (add the filter cost and the level of difficulty) I don't think it is worth the DIY. Just get the Winall unit.
For those who already have the Winall intake, it would be nice if you can do before and after dynos including a/f ratios for comparison.
Or ask Winall to provide the a/f chart. I would not buy until I see the a/f chart.
