Tire Pressure Question
Cla 45 2022. I went to look up what the tire pressure should be and the chart goes by speed rating for the tire. The tire is rated for 186 mph and on the chart on the gas cap door; it only has two ratings one 155 and 168 mph I called the stealership and they said that chart is for driving in Germany So he just said put 38 in the front and 37 in the rear .I asked where did you get those numbers, he said they just go by the tire . I decided I heard enough BS and moved on . So what pressure do you guys use front and rear .
It's not per speed rating of the tire. That chart is showing you an air pressure for most use and then what you need to bump it up to if you are driving really high speed. But what your dealer is saying is... you're not going to be driving over 250km/h so you don't need to use the higher tire pressure levels.
this is a picture I made with paint, is the official used system to calculate pressure for a certain load.
Its what you have to highen up the reference-pressure for higher speed, before putting it in the official formula. Standard load 36 or 35 psi, XL / reinforced/extraload, 42 or 41 psi. , most ZR tires are XL//.
I got hold of this formula end 2007, and went running with it, now call myself " pigheaded Dutch selfdeclared tyrepressure-specialist "
I determined in time my own formula, and simpler system for speed.
That last is , for every 10kmph / 6 2mph different/ 1 loadindex step different, higher speed/ lower loadindex, lower speed/ higher loadindex.
referencespeed I keep for all speedcodes ( also W and Y ) at 160kmph /99mph.
for the reference -speed and-pressure, the maxload is calculated by the tiremaker, and is given on sidewall.
For your 155mph= 250 kmph so 250-160=9li steps lower then given on tire.
then you only have to determine the weight on axles, the most tricky part in it all.
carmakers use GAWR's for it, or determined axleloads for 3 persons and a little load.
For speed carmaker uses max technical carspeed, or sometimes also given for 160kmph/99mph.
But If you know , you never go, not even for a minute, above 80mph, you could use that speed for determining best pressure. More comfort , but also more fuelconsumption.
I determined that for 160kmph/99mph determined pressure, and 10% added to determined axleload, gives maximum reserve, with still acceptable comfort and gripp.
Then calculating lineair is not even that bad, gives slightly to high pressure.
For who it interests the oficially used formula in Europe for all kind of tires , and in US for P-tires since 2006.
A=( B/C)^1.25 x D
In wich.
A is needed pressure
B is real load on tire
C is maximum load of tire
D is reference-pressure of tire( is cold and not the maximum cold pressure as given on P-tires)
^ 1.25 is power, like power 2 is squaire, and power 0.5 is root, on sciencetific calculators is a button X^y for that.
I When I checked my tires they were all at 40psi . Why is it so hard for Mercedes to give us the right pressure for the tires on your car for ever day use .That is why I asked the CLA 45 owners what pressure they use. I guess I will go with the lower pressure 36 35 .
A=( B/C)^1.25 x D
In wich.
Answer to post 4 and 5.
Its all a mater of responcibity, if carmaker gives that lower advice for normal day use, and only a few used that for heavy loaded and/ or high speed, only once , and tires overheat, and create little cracks, that dont disapear, and crack further in time, until mayby only after 3 years, that far that tire blows, or treath seperation, they sew the carmaker.
the couwardly high advice will never give overheating, only discomfort , and sooner punctures.
But if you give me 3 things of tires, I can make a pressure loadcapacity list for that tire per tire or per axle, whatever you like, and with reserve added, so you dont have to do that yourselfes.
then I make using 90% of the loadcapacyty belonging to the pressure.
These 3 things are, and can be read from sidewall
1. Maximum load or load index
2. Kind of tire to determine the reference-pressure
3. Speedcode( less important, have my own system
Oh, and give max speed you want the list for.
Then determining the wheelweights or axleweight stays your responcibility, and again, thats the most tricky part in it all.
I see some other posts here with Ph.D level engineering calculations being shown... don't worry about all that. Mercedes says 36 front and 35 rear.
To explain further... that chart is saying... if you are driving upto a maximum speed of 155 mph, have 19 inch wheels and are NOT carrying 5 people and a trunk full of heavy cargo... you use 36 front and 35 rear.
Here is a response from Michelin
Hello Steve,
Thanks for responding to my email regarding case 02950991. This will allow my team to quickly pull up your case details if any further questions arise.
I was able to look up the 2022 Mercedes Benz CLA 45 AMG 4 Matic. Looks like the original equipment for that vehicle is size 255/35ZR19XL (96Y). If you are currently running that size your PSI should be 39 in the front and 38 in the rear.
It also has an alternate original equipment of size 245/40ZR18XL (97Y) if you are running this size your tire pressure should be at 38 in the front and 36 in the rear.
If we can assist you further, please respond to this email or call us at 866-866-6605 (toll-free) between 8:00 a.m. and 7:00 p.m. EST Monday through Friday, or 9:00 a.m. and 1:00 p.m. on Saturday.
We appreciate your business and thank you for choosing Michelin.
Sincerely,
Kelsei
Consumer Care Department
Certified Michelin Product Expert
Made pressure/loadcapacity-list for the
Using 90% of the load capacity for the pressure for 99mph. This gives maximum reserve with still acceptable comfort and gripp.
So not for higher speed.
Now you "only" have to determine the axleweights, stays your responcibility.
Succes with that, is the most tricky part in it all
Underlined the max axleload ( 2 max tireload), and fat printed the reference-pressure for XL.
Cold pressure/ weight on axle
20 psi / 1453 lbs
21 psi / 1516 lbs
22 psi / 1579 lbs
23 psi / 1642 lbs
24 psi / 1705 lbs
25 psi / 1767 lbs
26 psi / 1830 lbs
27 psi / 1892 lbs
28 psi / 1955 lbs
29 psi / 2017 lbs
30 psi / 2079 lbs
31 psi / 2141 lbs
32 psi / 2203 lbs
33 psi / 2264 lbs
34 psi / 2326 lbs
35 psi / 2388 lbs
36 psi / 2449 lbs
37 psi / 2511 lbs
38 psi / 2572 lbs
39 psi / 2633 lbs
40 psi / 2694 lbs
41 psi / 2755 lbs
42 psi / 2817 lbs
43 psi / 2877 lbs
44 psi / 2938 lbs
45 psi / 2999 lbs
46 psi / 3060 lbs
47 psi / 3121 lbs
48 psi / 3181 lbs
49 psi / 3242 lbs
50 psi / 3302 lbs
51 psi / 3363 lbs
52 psi / 3423 lbs
53 psi / 3483 lbs
54 psi / 3544 lbs
55 psi / 3604 lbs
56 psi / 3664 lbs
57 psi / 3724 lbs
58 psi / 3784 lbs
59 psi / 3844 lbs
60 psi / 3904 lbs
255/35ZR19XL (96Y)
20 psi / 1453 lbs
21 psi / 1516 lbs
22 psi / 1579 lbs
23 psi / 1642 lbs
24 psi / 1705 lbs
25 psi / 1767 lbs
26 psi / 1830 lbs
27 psi / 1892 lbs
28 psi / 1955 lbs
29 psi / 2017 lbs
30 psi / 2079 lbs
31 psi / 2141 lbs
32 psi / 2203 lbs
33 psi / 2264 lbs
34 psi / 2326 lbs
35 psi / 2388 lbs
36 psi / 2449 lbs
37 psi / 2511 lbs
38 psi / 2572 lbs
39 psi / 2633 lbs
40 psi / 2694 lbs
41 psi / 2755 lbs
42 psi / 2817 lbs
43 psi / 2877 lbs
44 psi / 2938 lbs
45 psi / 2999 lbs
46 psi / 3060 lbs
47 psi / 3121 lbs
48 psi / 3181 lbs
49 psi / 3242 lbs
50 psi / 3302 lbs
51 psi / 3363 lbs
52 psi / 3423 lbs
53 psi / 3483 lbs
54 psi / 3544 lbs
55 psi / 3604 lbs
56 psi / 3664 lbs
57 psi / 3724 lbs
58 psi / 3784 lbs
59 psi / 3844 lbs
60 psi / 3904 lbs
20 psi / 1453 lbs
21 psi / 1516 lbs
22 psi / 1579 lbs
23 psi / 1642 lbs
24 psi / 1705 lbs
25 psi / 1767 lbs
26 psi / 1830 lbs
27 psi / 1892 lbs
28 psi / 1955 lbs
29 psi / 2017 lbs
30 psi / 2079 lbs
31 psi / 2141 lbs
32 psi / 2203 lbs
33 psi / 2264 lbs
34 psi / 2326 lbs
35 psi / 2388 lbs
36 psi / 2449 lbs
37 psi / 2511 lbs
38 psi / 2572 lbs
39 psi / 2633 lbs
40 psi / 2694 lbs
41 psi / 2755 lbs
42 psi / 2817 lbs
43 psi / 2877 lbs
44 psi / 2938 lbs
45 psi / 2999 lbs
46 psi / 3060 lbs
47 psi / 3121 lbs
48 psi / 3181 lbs
49 psi / 3242 lbs
50 psi / 3302 lbs
51 psi / 3363 lbs
52 psi / 3423 lbs
53 psi / 3483 lbs
54 psi / 3544 lbs
55 psi / 3604 lbs
56 psi / 3664 lbs
57 psi / 3724 lbs
58 psi / 3784 lbs
59 psi / 3844 lbs
60 psi / 3904 lbs
255/35ZR19XL (96Y)
20 psi / 1453 lbs
21 psi / 1516 lbs
22 psi / 1579 lbs
23 psi / 1642 lbs
24 psi / 1705 lbs
25 psi / 1767 lbs
26 psi / 1830 lbs
27 psi / 1892 lbs
28 psi / 1955 lbs
29 psi / 2017 lbs
30 psi / 2079 lbs
31 psi / 2141 lbs
32 psi / 2203 lbs
33 psi / 2264 lbs
34 psi / 2326 lbs
35 psi / 2388 lbs
36 psi / 2449 lbs
37 psi / 2511 lbs
38 psi / 2572 lbs
39 psi / 2633 lbs
40 psi / 2694 lbs
41 psi / 2755 lbs
42 psi / 2817 lbs
43 psi / 2877 lbs
44 psi / 2938 lbs
45 psi / 2999 lbs
46 psi / 3060 lbs
47 psi / 3121 lbs
48 psi / 3181 lbs
49 psi / 3242 lbs
50 psi / 3302 lbs
51 psi / 3363 lbs
52 psi / 3423 lbs
53 psi / 3483 lbs
54 psi / 3544 lbs
55 psi / 3604 lbs
56 psi / 3664 lbs
57 psi / 3724 lbs
58 psi / 3784 lbs
59 psi / 3844 lbs
60 psi / 3904 lbs
Made it with selfmade spreadsheet.
But tell me more about Rube Goldberg.
Edit: googled Rube, and dont agree that I make a simple thing complicated.
Now pressure determination is a lot of gambling, wich can lead to tire failure, and acidents.
My simple list only needs acuate axleweigt and max speed determination.
Composed already a new list.
Axleload for max 99mph/ psi/axleload for max 155mph.
51 psi is max allowed cold pressure for most normal car tires, some XL max 60psi, I could not underline the maxload at 155mph.
And mind max speed is the max speed, you wont go over for even a minute.
Also for 155mph I used 90% of loadcapacity belonging to the pressure, wich might be exagerated for a normal car.
But for 99mph this 90% gives max reserve with still acceptable comfort and gripp, and so can also be used for 75mph for instance.
99mph/coldpsi/155mph
1453 lbs/ 20 psi / 1116 lbs
1516 lbs/ 21 psi / 1164 lbs
1579 lbs/ 22 psi / 1213 lbs
1642 lbs/ 23 psi / 1261 lbs
1705 lbs/ 24 psi / 1309 lbs
1767 lbs/ 25 psi / 1357 lbs
1830 lbs/ 26 psi / 1405 lbs
1892 lbs/ 27 psi / 1453 lbs
1955 lbs/ 28 psi / 1501 lbs
2017 lbs/ 29 psi / 1549 lbs
2079 lbs/ 30 psi / 1597 lbs
2141 lbs/ 31 psi / 1644 lbs
2203 lbs/ 32 psi / 1692 lbs
2264 lbs/ 33 psi / 1739 lbs
2326 lbs/ 34 psi / 1786 lbs
2388 lbs/ 35 psi / 1834 lbs
2449 lbs/ 36 psi / 1881 lbs
2511 lbs/ 37 psi / 1928 lbs
2572 lbs/ 38 psi / 1975 lbs
2633 lbs/ 39 psi / 2022 lbs
2694 lbs/ 40 psi / 2069 lbs
2755 lbs/ 41 psi / 2116 lbs
2817 lbs/ 42 psi / 2163 lbs
2877 lbs/ 43 psi / 2210 lbs
2938 lbs/ 44 psi / 2257 lbs
2999 lbs/ 45 psi / 2303 lbs
3060 lbs/ 46 psi / 2350 lbs
3121 lbs/ 47 psi / 2397 lbs
3181 lbs/ 48 psi / 2443 lbs
3242 lbs/ 49 psi / 2490 lbs
3302 lbs/ 50 psi / 2536 lbs
3363 lbs/ 51 psi / 2583 lbs
3423 lbs/ 52 psi / 2629 lbs
3483 lbs/ 53 psi / 2675 lbs
3544 lbs/ 54 psi / 2722 lbs
3604 lbs/ 55 psi / 2768 lbs
3664 lbs/ 56 psi / 2814 lbs
3724 lbs/ 57 psi / 2860 lbs
3784 lbs/ 58 psi / 2906 lbs
3844 lbs/ 59 psi / 2952 lbs
3904 lbs/ 60 psi / 2998 lbs
255/35ZR19XL (96Y)
