Fuel door stuck
Old Jul 12, 2019 | 04:25 PM
Roger8's Avatar
A220
Fuel door stuck
I mentioned elsewhere that my passenger airbag warning light is now fixed but after I left the dealer and decided to fill up, the fuel door wouldn't open. I tried fiddling with it for a while but couldn't get it to open. Called Mercedes and they said to bring it back. They weren't able to find an emergency release and so the car is back in the shop. Current ETA is it may not be looked at till Tuesday so I'm in a loaner for the 2nd time in 2 months.
I read of a similar problem with the new 2020 GLE so wondering if they use the same mechanism. Either way, this makes me a bit more nervous in driving the car to a near-empty tank. I understand it's not a best practice to drive near empty but it never occurred to me I couldn't even fill up if I wanted to in that situation.
Old Jul 12, 2019 | 05:05 PM
Kenyon1976's Avatar
Buying One
You seem to have your fair share of issues. I'll be sure never to have my tank below 1/2 after reading about this.
Old Jul 12, 2019 | 05:18 PM
Roger8's Avatar
A220
Well, I figured since it's a brand new model that it might have a higher than average set of issues. That's why I got the extended warranty. At least the problems have been somewhat minor.
I read the 2020 GLE forum (we're also looking into that) and see people with more significant problems with the vehicle not starting or the main display dying. Given a lot of the electronics are shared between the two vehicles, this makes me a bit nervous.
Old Jul 19, 2019 | 09:30 PM
Roger8's Avatar
A220
Picked the car up after another week-long vacation at the dealer. Fuel door opens again. They replaced the plunger actuator thingy. The service person said "we've had to replace a few of these" which wasn't confidence building.
Another point for anyone interested... I had only filled the tank once before running into this problem. I know I tried the fuel door once when I originally got it (just to see it work) which means it broke after only 2 uses. I may go into the garage and give the new door a stress test...
Old May 30, 2022 | 11:07 PM
YU CHEN's Avatar
W213
Old Jan 30, 2023 | 12:59 AM
Moanes's Avatar
Originally Posted by YU CHEN
Hey, if I press it it will be released ?
Old Feb 4, 2023 | 06:35 PM
JonathanJabbour's Avatar
2021 Mercedes A220
Fuel door stuck. (FIXED)
thank you!!! The manual button worked. Was looking for this fix on the 25th of january and couldnt find it. No wonder i found it today, it qas posted on the 30th lol. You actually saved me. Thank you!!!!
Old Feb 4, 2023 | 10:54 PM
Moanes's Avatar
Worked for me too thanks to the previous post .
Old Jan 1, 2024 | 08:45 PM
Fury's Avatar
4 hooves and a cart
Hello,
I have a question - where is the release module located?
Trunk - left side area?
Thank you!
Old Jan 1, 2024 | 11:05 PM
Moanes's Avatar
Originally Posted by Fury
Hello,
Thank you!
It is located on the same side of the fuel door(left), to reach it you need to remove the panelling from inside the trunk from the same side.
