CLE Class Coupe (C236) & Cabrio (A236) 2023-
CLE53 Exhaust sound...lame?
Old Sep 9, 2025 | 08:27 AM
  #101
W205C43PFL's Avatar
Originally Posted by Rob_UK
Has anyone installed the ASR FLAP CONTROL RX2 MERCEDES (ML2-4PA)?
Or another module to keep the exhaust flaps open? Keen to understand what difference it makes.
It made a bigger difference in previous models but it doesn't seem to make much of a difference on the CLE 53. This module is also only good when you don't redline a lot and drive a low RPMs and want some low RPM rumble.
Old Sep 9, 2025 | 08:30 AM
  #102
W205C43PFL's Avatar
I just realized if you purely want more sound for free, just drop the seats. That said, I thought CLE 53 has something called real performance sound? If so the sensors should pipe in the sound to the speakers regardless.
Old Sep 14, 2025 | 03:45 PM
  #103
furio_CLE53's Avatar
CLE53
Do you have any recording how it sounds with straight pipes ?
Old Sep 14, 2025 | 03:47 PM
  #104
CLE53
Originally Posted by Driver2
Two points:
1) If the Real Performance sound was "symphonic" I might not have modified my exhaust. The MB quote seems like gaslighting to me. The EU has stricter noise regulations which is what led to the quiet exhaust and I don't think that MB has a real US spec exhaust system.
2) I had my mufflers replaced with straight pipes and the car sounds like it should, a nice rumble at idle and much louder at WOT with the appropriate crackle on decel but not obnoxious. The cost was $480. I previously owned a 2019 C43 and that exhaust sound was perfect. I drove with the flaps open all the time so this mod doesn't change that. The exhaust note when cruising on the highway at 70-80mph is still pretty tame because the single turbo straight 6 engine is just inherently quieter than the twin turbo V6. I have heard it said that the turbo is the muffler, lol. Also, I didn't change anything affecting emissions so I don't think that there is any warranty issue.
I have to point out that, since the aftermarket has not yet (to my knowledge and, I have contacted Burger Motorsports on this) cracked the MB CPU codes, the flap modules cannot be bypassed for model year 2024 and up. To address this I retained both exhaust flap assemblies in-tact and plugged in. The only snag is that I too get CELs that decode as exhaust flap failure, or something like that, from time to time because the installer insisted on welding the whole flap assembly to the straight pipes at 90deg. I'm pretty sure that the drivers side flap is interfering with the straight pipe and sticking. I hope that eventually it will clearance itself. There is some resonance at 2000-2300rpm where the exhaust is louder but otherwise the car is just about perfect.
Do you have any recording how it sounds now ?
I`m going to mod my exhaust , they basically open muffles and ripe them apart a bit . Will see how it sounds on Friday .
Old Sep 19, 2025 | 03:01 PM
  #105
Driver2's Avatar
CLE53
Exhaust note change...
I did make some video clips from the driver seat of the exhaust sound in my garage before and after the muffler removal but I didn't post them because there was so little difference in sound using this recoding method. And, because you can't rev the engine above 4000rpm in neutral, you can't duplicate the full throttle, 6000+rpm, sounds. Judging sound is a pretty subjective thing and these recordings just didn't make much of a case for the mod.
Having said that, when the car was backed out of the muffler shop by the mechanic after the mod I could immediately hear a nice rumble that wasn't there before but I didn't have the presence of mind to record that moment. The exhaust is definitely more noticeable while driving in C mode but not a huge increase from stock. There are definitely more burbles and it is louder than before in S+, but not obnoxious nor as loud as my C43 which made pops and bangs galore.
I have some theories on why the CLE53 without mufflers just isn't as loud as my C43 WITH mufflers. 1) the biggest reason I think is because the inline-6 is just inherently quieter than a V6, 2) there is more sound deadening in the CLE and 3) the engine/transmission performance mapping is tamer.
One of these days I'll try to arrange a drive-by and maybe a compare with a stock CLE53 or try to get my buddy to lend me his GoPro and stick it to the rear bumper.
Ciao.
Old Sep 22, 2025 | 02:57 PM
  #106
dmunozj's Avatar
AMG CLE 53
Here in Colombia is even worse....
Old Sep 24, 2025 | 10:47 AM
  #107
CLE53
Hey just modded my exhaust , middle muffler was removed and replaced by pipe with some net inside , right muffler was gutter results are good I`m happy with it . Its much louder , more pops and burbles in lower rpms , and also loud pops on higher rpm.
P.S you need to use speakers or headphones , on phone you wont notice diffirence.
Sample videos :
Old Sep 24, 2025 | 10:48 AM
  #108
CLE53
Ciao.
I recorded some afer modding check my post above
Old Sep 24, 2025 | 05:55 PM
  #109
Driver2's Avatar
CLE53
Talking Nice! Sounds like an AMG NOW!
Thanks for the vids. The exhaust sounds really loud in both the drive-by and in-car, especially in the tunnel.
I do have some questions:
1) What did you do to "gut" the passenger side muffler and did you then replace the empty shell?
2) Did you not do anything to the drivers side muffler?
3) Are the stock flaps still in place?
4) How did you match up a pipe to the oval pipe in the mid-muffler/resonator?
Old Sep 25, 2025 | 03:56 AM
  #110
CLE53
Originally Posted by is250
Nice bro. It looks like you were running Sport+ - how does it sound in Comfort or Sport mode? I'm asking since the car starts in Comfort mode by default.
In comfort its louder than stock but no pops. Still not super loud so its 100% fine
Old Sep 25, 2025 | 03:57 AM
  #111
CLE53
1) It is basically removed leaving just flap in place
2) No
3) Yes so no CEL
4) Just a straight pipe instead
Old Sep 25, 2025 | 01:19 PM
  #112
Driver2's Avatar
CLE53
2) No
3) Yes so no CEL
Thanks for the feedback. Enjoy the AMG sounds!
