CLE Class Coupe (C236) & Cabrio (A236) 2023-
Cooling System Malfunction
Old Jan 5, 2026 | 10:45 AM
David Jentink's Avatar
2016 C300
Ugh. So I get into my 2026 CLE53 this morning and get this message:
I am bringing it in tomorrow to the dealership. Anyone know what this may be? I am hoping just a weird glitch, but not happy when this happens on a car with 2000 miles.. :-(
Old Jan 5, 2026 | 06:50 PM
PHXATC's Avatar
2025 AMG CLE53, 2025 Range Rover P550E, 2025 Ford F150 Raptor
Have you seen leak anywhere? Evidence of one?
Old Jan 5, 2026 | 07:16 PM
2016 C300
I checked and nothing.
The temperature seems to stay level as well.
I made an appointment tomorrow at the dealer..
Old Jan 6, 2026 | 07:50 AM
PHXATC's Avatar
I would be a faulty sensor of some sort...or something along those lines. That's why they make warranties! PAIN in the bootie, however, beats having a broken car.
Old Jan 6, 2026 | 12:42 PM
2016 C300
Per the dealer- "Pressure regulation valve for the coolant system" They will perform the repair and I'll pick it back up tomorrow. FIngers crossed this is it and no more issues arise.
Old Jan 6, 2026 | 02:31 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Meaning...cap on the expansion tank....
Old Jan 6, 2026 | 02:49 PM
2016 C300
You know, I should have checked that. Honestly, it would make me feel a lot better if that actually was the issue..lol
Old Jan 6, 2026 | 09:35 PM
PHXATC's Avatar
Glad it was something simple.
Old Feb 10, 2026 | 11:48 AM
2016 C300
Well,
Back in the shop for the same message. This time they told me it is the Low-Temperature coolant pump. They are replacing. Strike 2!! The car has 3,100 miles on it and now has been in the shop twice for the same issue. I guess they have one more chance to fix it..:-/
Old Feb 10, 2026 | 01:59 PM
What engine do you have? A guy I work with in is wives car is on her fourth (yes, 4) engine under warranty. Starting with that message (hers is not a '16). It is a 2.0 4cyl.
Old Feb 10, 2026 | 02:08 PM
2016 C300
It's the 6 liter (It's a 2026 CLE53)
Old Feb 10, 2026 | 02:24 PM
Hers is an AMG 4 banger.
Old Mar 3, 2026 | 05:34 AM
cuddlesquid's Avatar
This issue came up on my custom order 2026 CLE 53 a few days ago after I washed it for the first time. The car has 235 miles on it. I used a pressure washer and sprayed the front grille, but not from a very close distance.
After starting the car, I received a yellow “cooling malfunction” warning message, and the cooling fan immediately kicked on at full speed, it was extremely loud. I let the car sit and dry for about four hours before trying again, but the problem persisted. I tried again the next morning and experienced the same issue.
I suspected water might have caused it for sure. I used a basic scanner to clear the fault code, and since then the car has been fine and no message. I live about three hours away from the nearest dealership; otherwise, I would have taken it in for inspection. I really like the car, I baby it a lot, I hope I don't run into more issues since I'm very far from the dealership.
