CLE Class Coupe (C236) & Cabrio (A236) 2023-
Microfiber Wheel Brush
Old May 1, 2026 | 09:57 PM
Rocketman1980's Avatar
2025 CLE AMG 53 Coupe
Has anyone found a good microfiber wheel brush that safely cleans the small cavities of the 20-inch multi-spoke Y-design wheels?
I currently use a microfiber wash glove but the fingers are too awkward to get into the cavities.
Old May 3, 2026 | 08:07 AM
PHXATC's Avatar
2025 AMG CLE53, 2025 Range Rover P550E, 2025 Ford F150 Raptor
I don't have those wheels, however I have 3 different sizes of MF brushes that I use for various wheels and nooks and crannies. Just get some off Amazon, that is easiest. Unless you are searching for a particular weave, water retention target, or color...they are all pretty much the same. I mean, we are talking about cleaning wheels, the dirtiest part of the car.
https://armourdetailsupply.com/colle...ry-wheel-brush as an example of a multipack.
Old May 8, 2026 | 08:32 AM
CPennino1's Avatar
2025 AMG CLE53
I am a big fan of the Obsessed Garage brush, it does a great job and is big/ long enough to reach well into the rim.
https://www.obsessedgarage.com/colle...detail-brushes
Another key is the wheel cleaner, I have been using P & S brake buster which is good but my favorite to date is Turtlewax Hyper Foam wheel and tire. I always get good results on all of my vehicles with this product and it can be purchased at your local parts store.
https://shop.advanceautoparts.com/p/...-tire-cleaners
Good luck
Old May 8, 2026 | 04:23 PM
Thanks for the info.
What wheels do you have that experienced the wheel cleaner? I have the multi spoke with black accents and don’t want to damage the brushed and painted surfaces in anyway.
Old May 8, 2026 | 07:31 PM
CPennino1's Avatar
2025 AMG CLE53
Sorry the large photo....
Most of the wheel cleaners out there are safe on 99% of the manufactured wheels, some of them may be more acidic or basic depending on the job. But I have used thee two I mentioned on my AMG rims as well as my F-150 and my wife's Genesis with no ill effects...
The cleaner really makes the job so much easier.
Good luck
Old May 8, 2026 | 10:38 PM
Nice looking car.
I like the black trim option for that body color. I selected that for my Sun Yellow colored 2025. I also had the small body colored roof sectioned blacked out with black PPF. It makes the roof look more uniform and clean.
I will try your cleaner on my wheels. I use a pressure washer with a foam canon to get into all the nooks and crannies. But spraying the wheels first will likely further ease brake dust removal and accumulation.
Thanks again.
Old May 9, 2026 | 06:59 AM
PHXATC's Avatar
I have the same black wheels as above and also use P&S Brake Buster cleaner. Never ever had a problem and have used P&S on our Range Rover, Cayenne, 911, and Raptor wheels all without a hiccup.
That cleaner does an okay job with the tires themselves as well, as long as they aren't really gunky and dirty, that should suffice as well. If they're really dirty, I use a dedicated tire cleaner.
Old May 9, 2026 | 10:03 AM
CPennino1's Avatar
2025 AMG CLE53
Nice looking car.
Thanks again.
Appreciate the compliment, very happy with the color combo, the only thing I do not like is the door handles being chrome, doesn't make sense if everything else is blacked out...
I'd like to hear your thoughts after you try the cleaner...
Good luck
