Considering a CLK320...
I am looking for a car in the mid $30Gs... and someone on the C-Class forum pointed me toward a Starmarked CLK... something I had not thought of before. my questions are pretty simple...
how sporty is the ride, I don't want a squish-box.
have you had any problems???
how is the pre-'00 transmission (without touch-shift)
How is the stereo?
how does the car behave in inclement weather?
The other cars I'm considering are mostly new...
'02 BMW 325Ci
'02 Audi TT Coupe (180 hp, Quattro)
'02 C230K (Loaded)
'70 MB 280SL
how do you think these all compare to the CLK...
This is a car I will take to see clients and attend social functions, I also enjoy driving, and am concerned that the CLK will just not be visceral enough for me.
your thoughts>>>?
i'll try to answer in order:
the CLK320 in its stock form is quite a "squish-box" perfect for a day with the clients. i'm sure many on this board will agree that if you're a spirited driver a good set of suspension springs will do wonders. in it's stock form it doesn't handle as well as a stock 325ci.
i've had no major problems...and from what i've heard the 325ci has had more build quality issues that the clk.
my friend has the 00' touch-shift tranny and he never uses it because the transmission is an engineering marvel as far as auto's are concerned. i like my auto. its the best auto i've ever driven. if the 00' had an BMW SMG II type setup then that's a different story.
as far as stock stereos the Bose system is above average. i've had no need to upgrade it. (i've worked at a auto electronics shop in the past so i suppose that might mean something)
inclement weather and S.Cali. now that's an oxymoron...sorry, can't help you there.
now the 70' SL is in a league of its own but as far as the 00' coupes the 320 is far superior imo. if you've got clients and may sometimes have to troll around your in-laws then you'd value the larger interior space, torquier (yeah, i made up that word :P) motor, and overall exclusivity of the CLK.
imho i'd choose the clk320...even w/ 10k miles its pretty much brand new. the BMW is smaller, there's more of them, but it is more of a drivers car. the TT is a two seater..need i say more? the c230 is under powered...you'll crave for more torque in that car. but you know what you haven't considered? you should take a look at a 01' Audi S4.
your thoughts>>>?
_____________________________________________
When in doubt, - throw it out!
However, you may get a biased response on this question b/c you posted in a CLK forum!!!
you guys mention that I will want to have the suspension (springs) changed to get a sportier ride, which companies seem to be the best... I saw that the H&Rs lower the car over an inch, and that seemed a bit much. has anybody used the Eibachs??? Also, will I need to replace the shocks, and who's work best... dynamically speaking, I like the ride of the 325Ci... so that is what I would want to emulate in the CLK.
techB: as far as reliability problems with the 325, what have you heard?
I can't (won't) insure the S4, and its a little pricey (about $41G)
https://mbworld.org/forums/showthrea...=&threadid=987
i can answer any questions you might have about this setup.
CLIFF
TEHY COMPARE.. THE BMW IS JUNK INSIDE ie. CHEAP..!!
and I don't have the $$$ to spend $5000 on wheels and suspension, I need something that works out of the box... a set of springs and inexpensive 17s are possible, but even that will require the gifting of a lot of shiny stuff to SWMBO... (she who must be obeyed)
BTW, stop yelling!
1. window realignment
2. seat cover replacement
3. oil cap replacement
4. tranny control module replaced due to occasional mis-shifts
5. getting a new dash next week because the leather around the passenger air bag cover has a hairline crack.
6. replaced the fuel gauge sensor or something in that system (can't remember the part exactly)
7. took in numerous times trying to get the rear deck to stop rattling ( i actually fixed this myself )
8. sunroof bug that never got fixed but mysteriously disappeared
9. the annoying creaks and rattles all cars have.
10. rear differential was leaking around 7k miles.
i'm sure there are 2 or 3 other minor things i forgot but luckily there hasn't been anything major wrong with the car.
about your suspension question...
-i use the H&R's because i've used them in the past and been happy with the compromise. start out w/ these as they will give you the best bang per dollar. then start thinking about the shocks down the line. then you if you want to go further ( for maybe the top 5% of total clk drivers :P )... get sway bars, etc...
both and make your own decision...!!! why go on what people say do your own DD on the cars and buy one..!!!!!!
CLIFF
I'm trying to make an informed decision, in part with the goal of minimizing TOTAL COST OF OWNERSHIP... thats the trick here... as for as my questions about how the car drives, the CLK drives fine... but I'm extremely reluctant to push the car anywhere near its limits with a salesmonkey in the passenger's seat... so I asked for the impressions of owners who have had this opportunity.
This purchase is a big deal to me. this is a lot of money and I'd like to make the best decision possible. each of the cars I listed represents DAYS worth of technical research, however, none of that can be substituted for the experiences of owners living in the real world. the only one of those cars i've not driven twice is the old SL, for obvious reasons.
I hope this makes some sense to you...
sounds like you've had some annoyances, of course thats about a dozen things over three years... one every oil change aint too bad i quess.
thanks again.
The ride is fine. Although it is more compliant than the BMW, it is also more fun to drive at the limit. Just turn the ESP off.
The stereo is great. Better than most of the aftermarket systems I have been suckered into buying.
I have a 1998 with 75,000 miles, and have never had a problem. Not one...
I would choose it over the others on your list...
Right not I'm leaning toward the C230 and the 325Ci... I can't seen to find any used CLKs with decent equipment under $38-39G... The Bavarian is like 33,500, and the C230 is like 32,+...
I'll keep looking though...
