Don't use Michelin Pilot Sport tires
Old Jun 24, 2005 | 12:26 PM
TomBeverlyHills's Avatar
2001 CLK430, 2000 E320 Wagon, 1992 300CE (sold), 1998 C280 (sold), 1995 C280 (sold)
I bought my 2001 CLK430 used (Starmark) a little over a year ago. It had a new set of Michelin Pilot Sport tires. The way it drove always irritated me. It would follow every little groove on the road and nearly jerk the steering wheel out of my hands in deep grooves. It wanted to go all over the road all of the time. I had it aligned and that didn't help. Last week I went to Costco looking at tires, and the saleman told me that they got a big memo from Costco corportate that told them they are not allowed to put Michelin Pilot Sport tires on Mercedes with AMG wheels, even if the customer asks for it. BUT, Michelin has taken care of the problem with the Michelin Pilot Sport A/S (all season) tires. Those have the same type of "gatorback" tread pattern, but with some noticable differences. I had them put on a set of new Pilot Sport A/S's on my car and viola, no more jittery pulling problem. Now the car drives like it's supposed to. If I would have known this a year ago I would have changed the tires out even when they were new. It makes that much difference.
Old Jun 24, 2005 | 03:12 PM
RX_Renesis's Avatar
335is
i think CLKs r like that? they thend to follow every little groove there is on the road.... it's specially bad when ur breaking hard and there's grooves on the road.... ur car will follow and turn.... my tires aren't from Michelin.... and i heard it was something about the steering something.....
Old Jun 24, 2005 | 03:22 PM
Chappy's Avatar
AMG
Interesting.
There is a Mercedes-Benz bulletin out about the A/S Pilot Sport as being a non-approved tire.
Glad you got your issue worked out.
Old Jun 24, 2005 | 03:42 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
well.... once you drive performance cars w/ performance tires more, you will understand what is going on. performance tires like the Pilot sport are considered maximum performance tires. they are very soft by nature, thats why they don't last very long. they are soft because they are designed to stick to the road, and you can't do that when the tire is hard as a rock.
by sticking to the road better, you develop a problem called tramlining... which means, your tires will follow the cracks and grooves, rather then the road intended. unless you are driving in a open ditch, i don't think the steering wheel will get jerked out of your hand.
if you think this is bad on 17s, just try driving with 19s on maximum performance tires...
Old Jun 24, 2005 | 04:10 PM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
Tramlining is caused by the tread pattern and type of grooved pavement. The tire's circumferential grooves will align with the concrete grooves...and when not exactly lined up, will cause the steering to pull to settle in the grooves, sometimes very firmly.
My pilot sports on my clk were fine on certain stretches of I-95, while Bridgstone SO-3s were pulling all over the place.
According to this label on my e, it looks like Mercedes doesn't want Michelins on the car.
Old Jun 24, 2005 | 04:27 PM
mmgrad's Avatar
and if you like to read... this is what TireRack has to say about it:
The term "tramlining" is being used to describe when directional control is disrupted by the vehicle's tendency to follow the longitudinal ruts and/or grooves in the road. It's name could be compared to the tram or trolley driver who does not steer because his vehicle follows the path established by the tracks.
Any vehicle can exhibit tramlining on certain areas of the highway because of uneven pavement or severe rutting. And all vehicles tramline to some degree rather than obediently following the driver's steering input. For example, there's usually at least a small change in steering resistance felt through the wheel when crossing an uneven expansion joint or asphalt junction during lane changes.
Noticeable increases in tramlining are frequently uncovered when drivers living in the snowbelt make the seasonal changeover from winter tires to summer tires, or when any driver upgrades the performance of their tires using either the same size or going to a "Plus Size" tire and wheel package. The reason that it becomes more pronounced then is because neither the typically narrower and softer handling winter tires nor the Original Equipment tires generate as much grip or responsiveness as the higher performance summer tires. Since the vehicle's suspension works as a complete package, a higher performance tire will also uncover any previously unnoticed looseness in the rest of the suspension.
Components
Tires have the most direct influence on tramlining because they are the part of the vehicle that comes into contact with the road (and the longitudinal ruts and/or grooves that exist there). Unfortunately anything that increases a high performance tire's responsiveness also increases its willingness to tramline.
High performance tires with short sidewalls that develop lots of cornering power at lower slip angles will be more susceptible to tramlining than standard All-Season passenger tires that develop less cornering force until their slip angle increases. A wider treaded tire will encounter more longitudinal ruts and/or grooves in the road than a narrow treaded tire. A tire with large tread blocks that transmits the driver's input to the road with great precision will also transmit the road's imperfections back to the vehicle's suspension. And because tires become more responsive as their tread depth wears away (which is why tires are shaved for competition and track use), a tire will become more likely to tramline as it wears.
Wheels can influence tramlining as well. Installing wider tires or a "Plus Size" tire and wheel package usually requires using wheels with a different offset then the vehicle's original wheels. In some cases, the new wheel will have slightly less offset than the original and in other cases, slightly more. It all depends on the vehicle's suspension design and available wheelwell clearances. You will even find that Original Equipment manufacturers often use different wheel offsets for their different diameter tire and wheel packages.
Usually the amount of offset change is kept to a minimum and vehicle tracking remains relatively unchanged. However it the offset is significantly different, it will alter the way the road forces are transmitted through the tire and wheel to the suspension. Therefore, large changes in wheel offset will increase the likelihood of tramlining.
Suspension bushings, ball joints and shock absorber mounts have a direct influence on tramlining as well. As miles are driven and the years go by, the suspension's wear parts will deteriorate as they age. This often happens so slowly that it isn't very noticeable. Over time the ever-increasing suspension wear permits play that eventually allows the tire to be directed by the irregularities of the road rather than be controlled by the suspension.
Imagine a worn suspension that allows a front wheel and tire to swing between the recommended 1/16-inch of toe-in and 1/16-inch of toe-out when it encounters a rut in the road. This 1/8-inch difference in the direction that the tire is pointed will result in the vehicle tramlining. Replace the worn part to remove the play and you will significantly reduce or remove the tramlining. Many drivers with higher mileage cars have reported that replacing worn suspension components has eliminated tramlining and made the car drive like it is new again...which I guess it essentially is!
Service Adjustments
Using higher tire pressures than recommended by the vehicle manufacturer for your driving conditions will unnecessarily stiffen the tire and make it even more willing to cause tramlining. If you are running higher tire pressures than necessary, simply dropping the tire pressures to those recommended by the vehicle manufacturer will help reduce tramlining.
Alignment settings can be key as well. The "camber" and "toe" settings both play a role in vehicle stability and the propensity for tramlining. Extreme positive or negative camber settings will make a vehicle more sensitive, especially when only one wheel encounters a longitudinal rut and/or groove at a time. Even if all the tires are "aimed" straight ahead when the vehicle is in motion, a tire that is "cambered" wants to turn. This is the result of the "camber thrust" generated by a leaning tire (it is also part of the explanation of how motorcycles turn). A vehicle suspension using lots of negative camber for competition or the track will experience more tramlining on the street.
Additionally, the drivers who use additional toe-out settings to encourage their vehicle to turn into corners better also encourage tramlining because the extra toe-out will reduce vehicle stability in a straight line.
In the case of the competition driver who uses non-factory alignment settings, the amount of tramlining that is acceptable has to be left up to the driver. For only street-driven cars, getting them aligned with negative camber and toe settings within the factory's specifications is an important first step.
Roads
On a multi-lane highway, usually the left lane offers the smoothest road surface because it sees the least amount of heavy truck traffic. Unfortunately, on many interstate highways, it's not legal to continually drive there (pull right except to pass). While the center lane can be almost as smooth on a six-lane highway, there can be exceptions. For example, in the case of I-94 between Chicago and Milwaukee, you will find that when the road was widened from two to three lanes, the center of the new center lane is on top of the original junction between the earlier two lanes. This means that vehicles traveling in the new center lane have their right hand tires on the original right hand truck lane and their left side tires are on the original left lane. This can cause an uncomfortable feeling for miles. Usually the right hand lanes are the least smooth because they are rutted by heavy truck traffic. When you drive in those lanes, or drive across them to exit the highway, it's possible that you'll find your vehicle may feel like it wants to follow the truck ruts and has a mind of its own.
Driving Style
If you experience tramlining, the main thing you want to remember is to keep both hands on the steering wheel in the proper "10- and 2-o'clock" position. This will help you make the precise steering inputs that will help keep your vehicle on course. You sacrifice precise control if you drive with one hand on the wheel or both hands in the wrong place.
Old Jun 24, 2005 | 04:33 PM
MarcusF's Avatar
2002 CLK430
At one time, Michelin Pilot Sports were one of the OE tires supplied with the CLK430.
Tramlining will occur in any tire that develops high cornering forces at low slip angles (slight turns of the wheel or influences by the road). That’s exactly what high performance tires do - they deliver mega grip. Since all-season tires don’t grip as well, you don’t see the problem. I've had the same problem with Yokohama AVS ES/100's on my Rx-7. I don't have the problem with the Conti Sport Contacts on my 430. Since you’ve already swapped tires, I guess it’s too late to tell you tramlining can typically be dialed down (if not completely out) by adjusting the air pressure (usually down).
Old Jun 24, 2005 | 04:35 PM
Stricks's Avatar
2011 E63, 2018 AMG GT Convertible
Tires
I've got them on my E class and had no problems. Of course, I'm in California were the road conditions are a bit better.
