Much anger right now, see if you can tell which pic shows why...
see if you can guess which one.
stock springs & aftermarket springs are designed to be the SAME height when uncompressed... the aftermarket springs may use less coils to allow for more compression
aftermarket springs that are cut, will have a shorter uncompressed height, which can lead to the problem shown above...
not to say that the car above has cut springs...
it does look like the H&R's are SLIGHTLY shorter than the stock springs?... but it looks like the car above definitely does not have cut springs.
When a spring is manufactured for a vehicle, the minimum and maximum length of the spring must be taken into account. Just as you want the spring long enough so it doesn’t fall out of the perch when the suspension is unloaded, you also don’t want “coil bind” (Is that the right term? Someone straighten me out if that’s the wrong phrase). Coil bind can happen when the bump stops don’t do their job. The bump stops are supposed to stop the suspension from bottoming out. Ordinarily they do, but the instructions in aftermarket springs say to “trim” the bump stops. Some people take that to be code for REMOVE the bump stops.
Not that anyone here cut springs, removed bump stops, or installed hydraulics. Lastly, if the half-unseated spring comes completely out, it may take out the brake line with it. That may result in a different kind of “bump stop”.
Good luck!
This happened on my Maxima with cut eibachs after hitting an unexpected railroad rack. With your springs and #3 pads, that is strange to see that at the least. You must have hit a SERIOUS bump.
I would investigate why this happed and make sure to check nothing else is wrong (shock bolted, control arm alright etc.)
Then if everything is OK, take it back to the place and show them. If they won't do it, just rent a spring compressor and do it yourself.
i actually wouldn't recommend using the spring compressor by himself.. it can be a pretty dangerous situation if you've never done this before. i've heard stories about people who try to install springs by themselves... and it's not a pretty visual
