Question for wheel fitment
Old Aug 14, 2005 | 03:29 PM
jinyoung1121's Avatar
01 CLK 320
I currently bought 1/6 carlsson 19"*8.5. Offset is ET 40. I went to shop to install them and it didn't fit in the front. The bolt was rubbing the tires. I think adding a spacer in the front is not good. I heard that it's wobble when I put the front spacer. What you guys recommend?? Should I get a new wheels or should I use the spacers in the front? Thanks guys for the comments.
Old Aug 14, 2005 | 03:59 PM
myNAMESterry's Avatar
991.1 gt3, w204 c63 507
are you talking about the lug nuts? if you're talking about the lugs being too long... just get shorter lugs.
Old Aug 15, 2005 | 03:21 AM
CLKonDUBS's Avatar
Piece of SH*T
I think he's talking about the A-arm/control bolt that comes down that hits the inner part of the tire..I've used spacers before but no problems with it shaking.
Old Aug 15, 2005 | 10:57 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
your car should be riding at best +35mm offsets... so, just put on some 5mm spacers and you'll be fine... as long as you use HUBCENTRIC spacers, else, you will notice that the wheel will shake
Old Aug 15, 2005 | 05:23 PM
01 CLK 320
Thanks for the advice. So I need to get hubcentric spacer now. Any specific company??Maybe H&R?? I got one more question. How about rear ones? Is 40mm offset O.K in the rear? I didn't even try to put them on the rear baecause it didn't work out in the front. Thanks again guys.
Old Aug 16, 2005 | 01:26 PM
mmgrad's Avatar
just stick with +35 all the around... for the rears, you even want to use thicker spacers if you want the wheels to be flush with the fender...
H&R makes good ones....
Old Aug 16, 2005 | 07:03 PM
CLKBSVegas's Avatar
a Black
not to cause trouble but...
I have H&R 5mm spacers on the front and do get a wobble
Old Aug 16, 2005 | 11:41 PM
01 CLK 320
I am kinda afraid that CLKVEGAS said about. He has a wobble in the front woth 5MM spacer. Thanks guys for the comments. I'll go for the 5MM ones for all four. After that I'll put some pictures in here. Thanks again.
