Sunroof issues
Old Aug 18, 2005 | 01:11 PM
nopepper's Avatar
02 S500
Sunroof issues
Anyone have problem opening there sunroof. When I hit the button it doesn slide open, It only open about 6 inches at a time, I have to keep hitting the button. Any ideas what this may be, motor? Switch?
Old Aug 18, 2005 | 02:40 PM
Bagher's Avatar
1999 CLK430
there is something obstructing the pathway, make sure there is no debris. you can 'reset' it by holding it in the open or closed position for a few seconds to hear a click and try again.
Old Aug 18, 2005 | 04:57 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
if you can open it fully manually, maybe you just need to reset the stop points for the sunroof....
Old Aug 18, 2005 | 05:11 PM
jtbeche's Avatar
02 E55; 99 CLK430 (Sold)
Happens from time to time on mine. Just get the sunroof all the way open and hold for a few seconds. Then close it and hold for a few seconds. It should work fine after that.
Old Aug 19, 2005 | 09:21 PM
patrick39's Avatar
01' CLK 320
yeah, you need to resync it and it should work fine.
Old Aug 20, 2005 | 12:31 AM
nopepper's Avatar
02 S500
i had it looked at by an electrican and he said it was the module...any truth to this or am i being taken?
nopepper's Avatar
02 S500
what do u mean by hold it? hod the button in after it has been openend? then hold it after it has been closed? for how long?
Old Aug 20, 2005 | 12:57 PM
jtbeche's Avatar
Exactly. Hold the switch like you're still trying to open it for about 7 seconds once it's all the way open. Then close and hold the switch again like you're still trying to close it. If that doesn't work then maybe it really is a faulty part.
Old Aug 21, 2005 | 10:52 AM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Sliding / pop-up roof
If you have the owners manual . I have an 03 /Found mine on green tabs,controls in details. Sub title , Sliding/pop-up roof* Pg 192. Look for , Synchronizing the Sliding/pop-up roof. It will go through the steps , Other wise ?? Hope this helps ___PTE___
