Car wouldn't start, ABS BAS ESP Lights on
Old Aug 23, 2005 | 02:18 PM
SFBAYCLK55AMG's Avatar
2002 CLK 55 AMG
Weird thing happened to me yesterday when I went to the car wash.
I parked the car so they could vacuum the interior and after they were
done could not start the car. The car would not turn over I can hear
it trying to start but no go. This really scared the hell out of me because
the night before I just installed the LED city lights and load equalizers.
Well another car pulls up behind me and offers to jump the car.
We jumped the car and my car was able to start. When the car started I got 2 malfunctions. The SRS and BAS ESP lights went on. I'm going to bring it to
the dealer on Saturday, it has 1 month left of warranty. After returning home
left it alone for a few hours and started the car. This time I'm not getting any malfunctions. Weird, I'm concearned that I was not able to start my car?
Just a few hours before this happened I went to muffler shop and removed
the resonators on my AMG exhaust. Any way this could all be linked, resonator and city lights?
Has anyone experienced this??????
Thanks in advance
Old Aug 23, 2005 | 05:14 PM
ThrillKill's Avatar
CLK/ML
I'll bet you unattached the battery cables when you installed the equalizers then didn't attach them well enough. If it lost contact you would essentially be resetting the ecu and get the warnings.....Just a guess.
Old Aug 23, 2005 | 05:46 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
the equalizers go on the lights, not the main power cable on the battery... how would an accidental detach reset the ecu?
Old Aug 23, 2005 | 05:48 PM
mmgrad's Avatar
maybe its just your battery going out...
Old Aug 23, 2005 | 05:57 PM
2002 CLK 55 AMG
I had a feeling that the muffler place may have disconnected the battery
while they were working underneath. I checked and the battery cables are still intact. If it happens again I'll think about replacing the battery. Hopefully it's not the alternator right??
Old Aug 23, 2005 | 06:17 PM
ThrillKill's Avatar
CLK/ML
No, I'm saying he purposly detached the battery prior to working on the lights and maybe didn't attach it back very well.
Old Aug 23, 2005 | 11:34 PM
mmgrad's Avatar
oic.... that is a possibility indeed
Old Aug 23, 2005 | 11:35 PM
mmgrad's Avatar
the muffler shop has no reason whatsoever to be disconnecting the battery to work down there... i would be more suspicious of their activities if they actually do disconnect my battery...
its like, would you need to disconnect your batteries to change your tires?
Old Aug 23, 2005 | 11:52 PM
clk22's Avatar
2003 clk55
i disconnected the battery today and i got the same warnings. Just drive it a lil bit and it will go away after like 5mins of drivin.
Old Aug 24, 2005 | 09:35 AM
ThrillKill's Avatar
CLK/ML
Bingo! Your ECU resets itself every time you disconnect the battery. It then relearns the settings as you drive. I doubt the muffler shop messed with the battery but SFBAYCLK55AMG probably did when he worked on his lights.
Old Aug 24, 2005 | 01:57 PM
2002 CLK 55 AMG
I didn't disconnect the battery when working on the LEDS. I've been driving
around for a few days now and no malfunctions so far.
Old Aug 24, 2005 | 05:33 PM
mmgrad's Avatar
how many times did you try starting the car before having to get jump-started...
Old Aug 24, 2005 | 05:55 PM
2002 CLK 55 AMG
I would say about 4 times, each time taking the key out of the ignition.
You can hear a click but the car doesn't turn over.
Old Aug 24, 2005 | 07:49 PM
mmgrad's Avatar
ok, then my other theory is out the door... because sometimes when you insert the key, the ir reader may not sync up with the key, and turning the key will do nothing and lots of error lights will be on... but, usually after you take the key out and reinsert it, it should work
if your car has been doin ok lately, maybe it was some kind of power/software hiccup... hopefully the problem doesn't resurface...
Old Aug 25, 2005 | 09:00 AM
Tru story's Avatar
I had a similar problem and it was my crank position sensor. After it was running for a while it would just shut off (while running) or wouldn't start at all if I ran into a store and came right back out. After it cooled down it would start again. CPS was replaced and no more problem.
I'd have that looked at. Just a thought.
Old Aug 28, 2005 | 03:30 AM
barflux's Avatar
CLK 320 Avantgarde
May want to replace battery, had a similar problem, mb road service came out and replaced the battery and all is well. I had the original battery for 5 years (which the guy said was pretty good)
Old Aug 29, 2005 | 08:34 PM
GCLK32's Avatar
This same thing is happening to my car. Car will start, after driving around, go into a store or where ever, come back out car will start, but after a little while, car will start. The other problem is sometimes car will shut down after driving around.
Tru story how much did dealer charge you to replace the crank position sensor? Also, how did the detect that was the problem?
Old Aug 30, 2005 | 05:04 PM
Tru story's Avatar
CPS Replaced under warranty.
Old Aug 30, 2005 | 08:28 PM
djamer's Avatar
SL 500
same here
Last weekend i drove my car around town, come home and attempt to lock my door, nothing happens. Strange. I try using the spare key. Same results. I get in the car, and attempt to start it. Key won't budge.
I called RoadSide Assistance, he popped the trunk and adjusted the battery terminal connection. He wrote up a ticket up for it to get fixed at the dealership no charge.
Once the car started, all the malfunction buttons appeared. The service guy told me to rotate the steering wheel all the left and then all the way to the right.. This readjusted the ECU. So far i haven't had any issues. I still need to take the car to the dealership..
