night time parking lights are out??
it all happened last week, when i put on the Carlsson Rs bumper, but i didnt connect the fog lights since i didnt have the right harness. so i left it disconnected for a week, and now that everythings connected....it no longer turns on when i shut the door at night. its not a big deal, but just curious if anyone out there had that go out on them also???
About your problem did you reset the time interval for the security lights (or whatever it's called?)
want to cycle through and view this setting to be sure it is activated.
go to radio shack (or a similar type store)
buy those harness connectors....the ones where you wrap them around the exposed wire (and it comes with a plastic harness where you insert like 5-9 of those connectors in to the plastic housing, but you wont need that...just the metal connectors)....then go back to your OEM fog light harness and remove the plastic housing at the tip of the wires...use a screw driver to lift the 2 tabs on the side and then they should come right off.....then slip the two wires with the new connectors ...and they should slide on easily...and there you have it...now ur ready to plug it in to the harness on the car.
hope this makes sense
i shall try the timer thingy....thanks for the tip.
blackbenz....they way i connected the angel eyes is the same as yours...but mine still work...good luck in your search to figure it out...if ur still trying?
model. Sorry if I mislead. I know the dealer set version covers my 99
and I thought that the digital menu models would have the owner selectable
option.
