W208 How To's
Old Jul 14, 2012 | 09:15 AM
  #176
J56BP's Avatar
2002 CLK 430
Really
Old Jul 15, 2012 | 12:11 AM
  #177
Just Is's Avatar
2001 CLK 430 w/5.4 swap, 2000 CLK430
Originally Posted by J56BP
Really
I believe I read that there are a couple spots on it where you insert a special tool to pop it loose.
Old Jul 15, 2012 | 12:34 AM
  #178
clk320pal's Avatar
CLK320 1999
Some help for your trim
Here some help for your CB projet
PAL
File Type: pdf
Old Jul 15, 2012 | 05:10 AM
  #179
J56BP's Avatar
2002 CLK 430
PAL
Old Jul 21, 2012 | 05:13 PM
  #180
GENEFEDON's Avatar
2002 CLK 430, '94 600SL
intermittent rough idle '02 clk430
MY 02 CLK430 RECENTLY STARTED IDLING ROUGH FOR 5-10 SECONDS THEN RETURNING TO NORMAL. THE CAR IS NORMAL WHILE DRIVING, THEN,WHEN WAITING AT A SIGNAL FOR 1-2 MINUTES, IDLE GETS ROUGH, RPM DROPS FOR 5-10 SECONDS, THEN ITS NORMAL AGAIN. IF STILL STUCK AT SIGNAL FOR 1-2 MINUTES MORE IT WILL DO IT AGAIN. I CLEANED THE MAF PER ALBERT'S INSTRUCTIONAL AND CHANGED FUEL FILTER. I AM ORIGINAL OWNER, CAR HAS 150,000 MILES. PLUGS CHANGED AT 100,000. NO MALFUNCTION LIGHT OR CHECK ENG LIGHT. LOOKING FOR IDEAS, THANKS.
Old Jul 28, 2012 | 06:28 PM
  #181
ThatsMyDawg's Avatar
SL 400
how to remove long wood trim top of dash ? we have total (w208) of 9 piece
wood trims, i wanna cover it with CF
plz any help
It pops right out. Covered mine with suede until I can get a new piece. (changing trim from dark to light wood)
Flat head between the wood and dash, a little prying and it pops out. You can hold the trim and pop the rest out easily by slightly pulling on the part you already got free. I started on passenger side and went towards drivers. Replace in reverse.
Old Aug 15, 2012 | 11:07 PM
  #182
Redw20855amg's Avatar
Blown 208 55 amg, 211 55 amg
Originally Posted by 787
Is there a write up for removing the lower control arms. I ordered some polyurethane bushings and I would like to remove the arms and bring them to a shop to get the bushings in. Any help appreciated
Where did you get poly bushings from? I've got d2rs coilovers and front rear hr swaybars polys would be a nice addition
Old Aug 16, 2012 | 03:25 AM
  #183
Keith437's Avatar
BMW
Dude, if you get a few more "how to" ideas, you can sell it in print. Nice write ups. It should help lots of folks here.
Old Sep 18, 2012 | 06:08 PM
  #184
dreamPR's Avatar
CLK 430
They should clean this thread up so it's a little easier to follow.
And making people pay for a how-to is pretty much the opposite of what a how-to stands for...
Old Sep 30, 2012 | 02:54 PM
  #185
Any audio expers know if both the subs in the rear deck can be upgraded to jl 6w3 still on factory amp?
Old Nov 18, 2012 | 10:35 AM
  #186
check the maf and airfilters
Old Nov 19, 2012 | 04:59 AM
  #187
newguy2008's Avatar
CLK 55 ///AMG Cabrio, ML63 ///AMG
Doesn't explain the RPM drops, but check the Engine Mounts. My CLK55 had similar issues and changing the 3 mounts resoled the rough idle issues.
Old Nov 23, 2012 | 03:00 AM
  #188
Marky876's Avatar
Clk320
The small peice of chrome/plastic around my drivers side keyhole somehow fell off while my sister was driving my car while i was in jamaica(idk the real story as the square cutouts in the side panels have fallen out too, one on each side ) so now my passengers side looks very flush and clean while my side has the ugly white plastic bit showing around the keyhole. any help on sourcing these parts??
Old Jan 29, 2013 | 01:38 AM
  #189
por2gezo's Avatar
2003 clk320
Subscribe
Old Feb 18, 2013 | 08:27 PM
  #190
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
I have noted after servicing the engine: Idle instability and hesitation on 2 occasions now,
To correct the problem each time I reseated the air box atop the engine. I think the fresh air leak was affecting MAF sensor.
Cheers, Gator
Old Mar 3, 2013 | 03:42 PM
  #191
DaSkorpion's Avatar
o2 CLK 55 AMG || o4 Audi A4 6SP Quattro || o7 Kawasaki Ninja ZX10R
Thanks for your post (#14) mmgrad - I just tackled this 30 mins ago and your guide made it a breeze.
Old May 12, 2013 | 01:52 PM
  #192
lukeinla's Avatar
W208 430 Cab
hey guys..bought the car off someone noticed the low beam only seemed to light up a couple of feet in front of the car..ordered the H7 osram bulbs swapped them out...looked good at first (although it was daytime) tried them out and same issue as before..my fog lights light up more of the road than my low beam.. any ideas?
Old May 12, 2013 | 02:25 PM
  #193
sirswift93's Avatar
CLK320 Cabrio 2001
Did you replace the headlights after an accident or just renew them. Possible they were never aimed. You just need to aim them. You can find this info online and shine your lights on your garage door or wall and follow instructions. You don't need special tools for this.
Old May 12, 2013 | 02:27 PM
  #194
lukeinla's Avatar
W208 430 Cab
thanks..i did consider this..however gave up trying to figure out how to do it from the manual..i will give this a try and report back ...cheers
Old May 12, 2013 | 06:09 PM
  #195
GatorMB's Avatar
Sir swift is on the right track with a headlight alignment check. I am going to write that down!
I am running OEM xenon and like the look but they don't have any punch. I have to use fogs/driving lamps on unlit roads. The xenon has a stunning appearance though. I am considering projectors, most of my commuting is at night.
Gator
Old May 13, 2013 | 10:54 PM
  #196
lukeinla's Avatar
W208 430 Cab
Not an issue of angle. When I look into the headlight the only light coming from it is from the actual bulb..
Old May 28, 2013 | 03:50 AM
  #197
mufasa77717's Avatar
1999 Mercedes-Benz CLK430
How to change Differential Fluids
I need a big favor from you awesome helpers! I need instructions on how to change the differential fluid on my 1999 CLK430 (: & recommendations on differential fluid to use on this car!
Thank you so much for this How To's! Major help! (:
Old Jun 12, 2013 | 05:02 PM
  #198
jkiddd33's Avatar
2005 E55 AMG
I had mine checked today.. There is a screw that will drain the differential and another screw that you will let you fill it up.
Its regular 80/90... I just bought 2 quarts today.
Old Mar 7, 2014 | 05:55 PM
  #199
nuno_gt's Avatar
W201
i don't know if it's repost but, anyway, here it goes: how to remove the entire wood trim front center console, upper trim that goes from one side to another, and the door's wood trim.
Waiting for answers from you.
Thanks in advance
Old Mar 23, 2014 | 12:33 AM
  #200
avalotalantra's Avatar
CLK 200 1998 convertible
thanks for the window adjustment PDF mine in my new to me clk 200 convertible need an adjustment
You have already rated this thread Rating: Thread Rating: 8 votes, 4.75 average.
