Break installation
Old Nov 22, 2005 | 12:43 PM
BLACK2001CLK's Avatar
2001 CLK 430
Break installation
Guys,
So I bought a set for Zimmermann's cross-drilled rotors for front and back and Porterfield pads. They about to arrive this week. Here is my question to you. I've never installed breals myself, I do want to do this this time. Is there anything I need to do/know. Any tricks or this is all stright forward. Can some one post DIY instructions, if any available.
Also, I got Breakline Wear message, are those breaklines, or breaks themselves?
Old Nov 22, 2005 | 01:51 PM
clkgeorge's Avatar
00 clk 320 and 3 hondas. Darn I am down to 4 cars.
Oh you mean brakes!
Very straight forward, remove wheel and the calipers unbolt from the back.
A couple of bolts and they come off.
One thing is that you might need a C clamp to push back the cylinder when you install the new pads. If the cylinders have a slot on them, then use a large flat head screw driver and turn them clock wise.
If you have to use the C clamp, use the old pad to push the cylinder back. Uncap the brake reservoir before you clamp down, and remember to recap after you are done.
Old Nov 22, 2005 | 02:00 PM
2001 CLK 430
Do I need to replace breaklines, since I got that message?
Old Nov 22, 2005 | 02:06 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
No the brake wear indicators will illuminate that light when they make contact with rotors, make sure you change those sensors, not your brake lines.
Old Nov 22, 2005 | 02:07 PM
clkal's Avatar
01' CLK55
i guess you didn't read CLKGEORGE'S comments about your BRAKES.....lol
Old Nov 22, 2005 | 02:31 PM
2001 CLK 430
Alright, I will work on my breaks as soon as I have time.
If I don't post results with pictures, that means install wasn't sucessful and I'm not with you anymore
Old Nov 22, 2005 | 05:05 PM
clkgeorge's Avatar
Go ahead buddy, let us know how your "breaks" come out. LOL!
Old Nov 22, 2005 | 08:23 PM
bs00clk's Avatar
2000 Silver CLK430
Uh, is there an echo in here? Hey BLACK2001CLK: Don't break (to destroy something) your brakes (a system for stopping vehicles) while working on them...
