New Tires.... Vibration
Old May 3, 2006 | 05:48 PM
amr's Avatar
amr
2001 CLK55
Just got 19s Falken Azenis ST115 (245/35 & 275/30) and they were mounted and balanced but now I'm feeling every road vibration.... is this normal with 19s or is there a balance problem. The car has Koni/H&R setup as well.
Old May 3, 2006 | 10:18 PM
smalldog's Avatar
clk
I have 19" Falken Ziex ZE502 and I get a vibration that comes and goes. Usually the shake/vibration is @ 60mphs. I notice the shake/vibration goes away when the tires are warm. It's time for me to buy new tires and Falkens wont be my choice.
Old May 4, 2006 | 01:25 AM
bs00clk's Avatar
2000 Silver CLK430
What were you riding before the 19s?
Old May 8, 2006 | 09:42 AM
amr's Avatar
amr
2001 CLK55
Stock setup (17s with 225/45 and 245/40).
I get the vibration at about 55-65 mph and then it goes away at higher speeds. At 100+ mph, it's smooth as silk... go figure! I think it may be just a balancing issue, but then I also noticed that my tire pressure seems a bit high... it's 34 psi all around... shouldn't it be about 30-32? Maybe the excessive pressure is making the tires a bit hard and causing additional vibration... just a thought?
Old May 8, 2006 | 10:06 AM
bs00clk's Avatar
2000 Silver CLK430
I just got new tires on my stock wheels and have a slight vibration at the same speeds. Pressure isn't probably it but it's easy to figure out...just remove a little. I run 35 PSI and my tire dealer recommends at least that. Said I could go higher if needed. Let us know what you find out.
Old May 13, 2006 | 12:09 AM
tibimakai's Avatar
2000 M-B CLK 320, 2008 VW Rabbit
try road force balancing(not every place has it)
Old May 13, 2006 | 12:49 AM
bs00clk's Avatar
2000 Silver CLK430
Can you elaborate on what this is? Never heard of it...
Old May 13, 2006 | 06:20 AM
doramon's Avatar
W208 CLK 320 Yr 2000 & W203 C200K Yr 2003
have u done on wheel balancing? meaning the front wheels are jacked up and balanced on the spot...over here we call it as " high speed balancing" running on 36 psi
Old May 13, 2006 | 06:21 AM
doramon's Avatar
btw mine is also falken st 115 235/40/18 and 265/35/18
Old May 14, 2006 | 07:13 AM
Taximan1's Avatar
2005 E55, 2004 E55(sold), 2001 Viper GTS, 2006 Viper VOI9, 1994 ZR-1 Corvette 2009 Viper ACR,
vibration
you need hubcentric spacers..
Old May 14, 2006 | 08:43 PM
myNAMESterry's Avatar
991.1 gt3, w204 c63 507
rear wheels are cambered. get a wheel allignment and/or get camber kit from speedybenz.com
Old May 16, 2006 | 12:41 AM
tibimakai's Avatar
see here what it is:
http://www.hunter.com/pub/product/ba...159T/index.htm
you have a place locator too on the bottom of the sceen
I would suggest checking the wheel bearing play too(12 and 6 o'clock play)
Old May 16, 2006 | 12:43 AM
he can try it.. but i'm almost positive that it's not that. bigger wheels, more camber.
