BAS ESP, ABS light
Old Oct 22, 2006 | 06:33 PM
s.f.clk02's Avatar
CLK320 2002
BAS ESP, ABS light
well today after driving my car from work these 3 malfunctions popped up today and got me worried. i am not sure what they are, before they would pop up and i would restart the car and they would disappear and today they came back so now i am wonder what they are and what do i need to fix them. would i need new brakes ?
Old Oct 22, 2006 | 08:08 PM
buysellguyct's Avatar
2001 CLK320
Hey there, I have had the same thing happen to me in the past! Never had confirmation that they were truly linked but everytime I need brakes it happens to me!
Old Oct 22, 2006 | 10:58 PM
Silverbillet's Avatar
2001 CLK430 Cab; 2008 GL550
I had the same thing happen to me a week ago. I did a search and it is caused by a faulty brake switch that cost $8.00 for the part and 15 mins to replace. I haven't replaced mines yet because it was the first time it happened, but eventually I will. Do a search on this forum or the benzworld forum and you will find more details.
Old Oct 23, 2006 | 01:00 AM
s.f.clk02's Avatar
CLK320 2002
tell me if it works out fine when u do the install on that little switch. but i think i still need to get new breaks too.
Old Oct 23, 2006 | 06:53 AM
tomtomtomtom's Avatar
02clk55///2010GLK350
Sometimes it just has to be recalibrated...taken from the other list....Calibrate your ABS and ESP systems by turning the steering wheel all the way to your RIGHT and then all the way to your LEFT. then bring it back to the midle. Notice the two yellow lights desappear from you dashboard.
Old Oct 23, 2006 | 05:58 PM
Mach430's Avatar
You may have to press the brake pedal while following Tomtomtomtom's instructions, but he has it right.
Old Oct 24, 2006 | 08:13 PM
jesone430's Avatar
2000 clk430
My cAR was doing that on start up.. The battery was getting weak and that was the culprit...If u feel your car having a hard time cranking over, chances are a battery on the outs is popping the lights..9 or on cod starts))
Old Oct 24, 2006 | 10:05 PM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
If that steering wheel turn technique doesn't fix the problem you may need to replace the brake switch and its an easy fix. I assembled a fix with photos in the DIY section. Costs only about $20-25 and 10-15 of your time.
Old Oct 25, 2006 | 02:05 AM
s.f.clk02's Avatar
CLK320 2002
yea thanks for the help im just waiting for the sighn to pop up again it usually happens after i drive for about 15 mins. ill try the steering wheel then.
i just love how these problems keep popping right before i install my shocks spring and rims. i just love it.
