Turn signal blinks continuously
Old Dec 1, 2006 | 05:33 AM
number10's Avatar
CLK 200 (2001)
Hi, I have a problem with my 'Turn signal (indicator)' in the dash board. the Left one blinks continuously as therefore do all my exterior turn signals.
Has anyone heard or experienced this kind of problem.
Thanks for reading and trying to help out.
Old Dec 1, 2006 | 10:51 AM
Motivation's Avatar
CLK 430 Coupe
i haven't ever experienced this, but did you try checking the relays and fuses? or resetting the computer?
Old Dec 1, 2006 | 12:43 PM
Whodat's Avatar
2000 CLK 430 Cabriolet
Sounds to me like a flasher switch is malfunctioning.
Old Dec 1, 2006 | 01:25 PM
Whodat's Avatar
number10: I highly recommend you go to:
http://www.mercedesshop.com/shopforum/
Get yourself an account. Mechanics hang out in this site. I already posted your question. All you have to do is wait for a reply.
Path: ShopForum ---> TechHelp (Gasoline engines) ---> and then the thread "w208 - turn signal" (I use my same handle/name on that site)
Old Dec 1, 2006 | 04:00 PM
Hitman0187's Avatar
CLK430
ive seen stupid things like that happen when the wrong bulb is in the socket.
while i know these arent interchangeable its for an example purpose an h7 in a L194 socket.
Old Dec 4, 2006 | 04:29 AM
number10's Avatar
CLK 200 (2001)
Thank you, I'm goona have a look at this website.
Old Dec 4, 2006 | 04:31 AM
number10's Avatar
CLK 200 (2001)
Hi Hitman, I've not changed any bulbs myself or the mechanics.
So surely it can't be that, could it?
Thanks for your help though.
Old Dec 4, 2006 | 05:16 AM
number10's Avatar
CLK 200 (2001)
Thanks for all your replies.
Just to add a bit more info... The car was in the garage a few weeks ago with an ignition problem. They replaced that but said that the SRS sensors have come on and had to replace two of them.
Since then a couple of the electronic diplays look to be malfunctioning. i.e the LED for the temperature & the Gear LED's are not showing fully.
So could there be a bigger problem than just the tur siganl. Could it be a loose wire or something?
Thanks guys.
