Just changed the my side mirror lights to clear
Old Sep 20, 2002 | 07:24 PM
GBD's Avatar
GBD
CLK55AMG
Ivan.. What # Silvervison for the turn signals front and back and where did you get them? Thanks in advance!!
Old Sep 20, 2002 | 09:29 PM
CLK_Ivan's Avatar
2001 CLK430
I made them myself with Rustoleom high heat silver spray paint. It's about $4.99 at Home Depot. It just takes a few passes back and forth on each "side" to cover the entire bulb.
Easiest mod ever.........
Old Sep 20, 2002 | 10:18 PM
err0neous's Avatar
02 CLK 430 Coupe
They still blink orange, right?
Old Sep 21, 2002 | 02:10 AM
CLK_Ivan's Avatar
2001 CLK430
Yes, just try not to overspray the bulb. It will still blink orange,but if you spray too much it will be a little dimmer.
Old Sep 21, 2002 | 06:58 PM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
I was so excited... I took pre & post install pics
and set them up nicely for comparison and for your viewing pleasure:
Take a look
Blinkers Off:
Blinkers On:
Old Sep 22, 2002 | 01:27 AM
Mach430's Avatar
What did you change your bulbs to? Does yours still flash orange during the day, or only at night?
Old Sep 22, 2002 | 01:55 AM
  #32
mmgrad's Avatar
Mach430: before i make a fool outta myself, was this question directed to me or Ivan?
Old Sep 22, 2002 | 03:18 AM
  #33
tery's Avatar
CLK320
mmgrad please read your PM
Old Sep 22, 2002 | 08:28 PM
  #34
Mach430's Avatar
How would it make a fool out of you? I was in no way trying to, so I apologize. Actually, I'm very intersted in changing my mirrors now. The question was to you.
Ben
Old Sep 22, 2002 | 08:30 PM
  #35
Steph's Avatar
thanks for the post Kevin.....I now have hyper-white mirror signals...not too ricey I hope.
Old Sep 23, 2002 | 12:47 AM
  #36
tery's Avatar
CLK320
where to get thos hyper white mirror light ?
Old Sep 23, 2002 | 01:03 AM
  #37
mmgrad's Avatar
tery & steph- i'll post the respond to your PM here in case others are interested.
Old Sep 23, 2002 | 01:25 AM
  #38
mmgrad's Avatar
Ben
No apology needed. I just didn't want you to think that every question was for me by answering every question based on my install.
The bulb is a regular clear light bulb, so therefore it will emit a slightly dirty white (like regular halogen headlights), the picture actually depicts it to be more yellow than it is. So, it blinks quite WHITE throughout the day & night. NO PAINTING NEEDED!!
In the original post by KevinV, he said to use a Sylvania 2721 bulb. This would work, but I opted for the 2723 bulb (2.3 Watt output versus a 2.1 output) which is a little brighter.
Available at PepBoys for $1.99 per pack. $1.79 at AutoZone (but they only have 2721).
All you need to accomplish this job is 3 Packs (6 bulbs). Each mirror housing consists of 6 bulbs as Kevin stated.
You can change all 6 bulbs, but its not necessary. In actuality, changing all 6 bulbs per housing would make it less bright since every 2 bulbs share 1 power source, splitting the output capacity. By simply installing the outer 3 bulbs, it will shut off the other 3, but don't pull them out, else none will work.
If you need installation instructions, let me know.
Again, for your comparison:
Factory Passenger Light
New Driver Side Light
Old Sep 23, 2002 | 01:29 AM
  #39
tery's Avatar
CLK320
can anyone tell me where to buy those 2723 bulbs in Canada Vancouver ? Canada dont' have pep boyz.
i really need to buy one , i break two bulbs and two flash other colour becuase i spay paint it sliver.
Old Sep 23, 2002 | 01:52 AM
  #40
mmgrad's Avatar
tery:
If you want, I happen to have an extra 3 sets because I initially wanted to change all 6 per housing.
PM and we'll work out the details.
Old Sep 23, 2002 | 01:58 AM
  #41
tery's Avatar
CLK320
check you pm mmgrad !
Old Sep 23, 2002 | 02:15 AM
  #42
tery's Avatar
CLK320
check your pm again thanx
Old Oct 27, 2013 | 11:23 PM
  #43
johnnr's Avatar
ML350 4Matic and CLK 430
CLK Stock Side mirror bulbs
Hey All, if I want to just replace a stock bulb that burnt out....
On the w208, the door mirror turn signal bulbs; there are 6 orange bulbs in total in each mirror (3 along the reflector, and 3 in the back). I removed them and it seems the two sets (reflector and back) have ever so slightly different bulb numbers.
- OS 6/2Y w1M and
- OS 6/2Y w1N
I'm pretty sure the OS is "Osram Sylvania" (the brand of bulb)
Does anyone know the difference between these and how to get them?
Or is difference nothing to worry about. I can't find these on the Sylvania website or anywhere...
Old Oct 28, 2013 | 12:44 AM
  #44
Scott Simoncic's Avatar
2001 CLK55 AMG
So there's 6 bulbs ya? What if one were to do a flashback type of deal, where 3 of them are the equivalent to 5000K LED, then the other 3 Amber, have the 3 5000K's on with the parking lights, and 3 Amber to flash with the signal. Hmm, or I was actually thinking right now of doing two stage, Full brightness during the day as DRL's, then half-brightness when I turn the lights on.... Hmm, I'm not down with the usual Copy-cat New Mercedes look, This would be a little unique.... Ideas flowing.
Old Oct 9, 2020 | 08:22 PM
  #45
quik55's Avatar
2000 ML55 AMG 2001 CLK55 AMG coupe 2002 CLK55 AMG Cabriolet 2025 BMW M2 6MT
Has led technology advanced since this thread? Do they make 2721 led bulbs that should work in the mirror lights? Looks like there's tons of options for them
just curious
