Disaster stuck while changing plugs on 320
This does sounds like huge mission, good luck.
It is a bolt extractor .. you need to drill in to the center of the plug ,and insert the easy out inside the hole that you drilled ,then use a good grip to twist the easy out of the bay. Try to get the proper size for the easy out , I hope this will work . Good luck dude
Did you try spraying any stuff like wd-40? if you did then your mechanic / friend gave you good advice about taking it appart, good luck!
Good luck fella. Hope you get it sorted.
I asked Krayzie_99 if they were the original plugs because sometimes people cross thread plugs -then the guy who goes to change them later has a problem.
Krayzie_99, give us some details. Did the plug loosen a little first, tighten up, and then snap? Was the engine dead cold? How hard did you have to lay on the socket before the plug snapped?
In addition to Marcus's questions, I will ask, was the socket firmly seated into the a spark plug before you tried to break torque? It's important that the socket was in all the way.
I am new to this whole forum thing and don't know yet how to attach pics or drawings or links. I will be on the proto website and write back the old fashioned way. Back in ten minutes.
