AC problem 01 CLK 430...
Old Jan 2, 2007 | 08:25 AM
Idle Swede's Avatar
01 430 CLK, 85 RR Silver Spur, 90 Bentley Turbo R, 93 FLSTN
All of a sudden my AC is not blowing as cold as it used to, any ideas..?
Old Jan 2, 2007 | 08:43 AM
CLK430girl's Avatar
2000 CLK 430
Maybe a leak in freon...its worth a look
Old Jan 2, 2007 | 08:53 AM
Idle Swede's Avatar
Yes it is & I'll check that today...
Old Jan 2, 2007 | 10:35 AM
Idle Swede's Avatar
Anyone else..?
Old Jan 2, 2007 | 07:09 PM
Hal H's Avatar
2001 CLK320
There's a couple of items to check out -
* as other's have said, check the level to make sure the refrigerant isn't low.
* the W208 has A/C plenum sensors that can go out (I've had this happen in the past) and those will control how cold the A/C will get as well.
There's a body control module that the dealers use the SDS to pull codes from to see if the sensors are working properly or how much pressure (measured in Bar) there is within the high or low side of the system.
Old Jan 2, 2007 | 07:56 PM
Idle Swede's Avatar
Thanks for the advice.
Freon was low by 75% and they are now checking for leaks.
Old Jan 4, 2007 | 12:51 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
you can also replace or clean out your cabin filter...i cleaned mine out at 75k and it had all sorts of leaves dirt...
Old Jan 4, 2007 | 01:23 AM
BeNzTeK's Avatar
usually the reciever drier goes at least it did with mine
Old Jan 4, 2007 | 09:28 AM
Idle Swede's Avatar
Very Strange...?
Well, after recharging the freon & checking for leaks, Nada..?
AC now blows cold, there are no leaks after missing almost 1.5 # of freon.
Any ideas?
