Check Engine Light
Old Jan 4, 2007 | 06:32 PM
SeNia_CLK's Avatar
2001 CLK 320
Check Engine Light
So I am driving on the highway today and notice my check engine light on. I was out of town for a few days so I am not sure what exactly happened to the vehicle and who exactly was driving it in the family, but before I start poitning fingers I need to know what exactly happened. It feels like the car only uses half of its power right now. It lost its kick. Guys does this mean I might need to change my MAF? I am sure someone experienced this before. Please help!
Old Jan 4, 2007 | 07:13 PM
MMM430's Avatar
'00 CLK430 & '08 Lexus RX 350
First....check that your gas cap is on tightly! That can actually lead to a Chk engine light. If not the culprit...go to shop
Old Jan 4, 2007 | 07:43 PM
jtbeche's Avatar
02 E55; 99 CLK430 (Sold)
Personally, after double checking the gas cap is on tight I'd go to Autozone or Pepboys or somewhere and have them check the codes for free. Then come back here and do a search on those codes. I'm sure someone has posted the ones that you end up pulling. If you're losing power it sounds like a MAF issue to me but I'd definitely pull the codes first and avoid the dealership until you know what you're dealing with.
Old Jan 4, 2007 | 10:26 PM
Whodat's Avatar
2000 CLK 430 Cabriolet
I agree. I actually have to have my MAF changed now because I failed MD emissions. Not because of 'bad' exhaust smoke (or lack of power) but because when they hooked it up to their computer, the dreaded codes came up. My mechanic warned me this was going to happen but I had to do it (and fail) because I was going out of town.
The codes for the bad MAF are reflected with wording like 'Fuel trim malfunction' or something like that. There'll be two of em, one for each bank of cylinders.
Old Jan 4, 2007 | 11:38 PM
SeNia_CLK's Avatar
2001 CLK 320
I made sure to check my gas cap before posting here. Thats not the problem, man I just replaced my crank shaft positioning sensor last week and now this?! I wonder if this has anything to do with Canadian winters? I don't think there is Pepboyz or Autozone here in Canada which puts me in the **** out of luck category. So I guess I have to go tothe dealership now to get codes. I've done an exceptional job aoiding the dealer so far
Old Jan 5, 2007 | 12:04 AM
Whodat's Avatar
Shoot, I've NEVER been to the dealer (yet). But I've only had the ride for about a year. And you have a different set of resources living in Canada.
Anyway, hang in there. I've had to change my CPS, and now my MAF too so you're not alone. I'm sure 90% of the guys (and gals) out here have had these parts go bad back-to-back too.
Old Jan 5, 2007 | 10:38 AM
MarcusF's Avatar
2002 CLK430
You could buy an OBDII code reader. I bought mine for about $60. It plugs into the existing OBDII port, tells failing code, comes with a list of what those codes mean, and allows you to reset them.
Old Jan 5, 2007 | 12:12 PM
SeNia_CLK's Avatar
2001 CLK 320
Whodat I guess statistic like that does make me feel like I am not alone. Hey is there anything else I should be expecting sometime after dealing with the MAF? Besides CSPS that is very common?
Marcus I am going to seeif I can get my handson the code reader man. Thanks a lot!
Old Jan 5, 2007 | 10:51 PM
Medicaptain's Avatar
Maf
I need to change my MAF...anybody know how hard it is to DIY and how much the part is?
Old Jan 6, 2007 | 12:19 AM
SeNia_CLK's Avatar
2001 CLK 320
Hey man I found one on Ebay is this the one you have? Just curious because there is actaully a more expensive model. I am trying to figure out if this is all I need:
http://cgi.ebay.ca/Professional-OBDI...QQcmdZViewItem
or should I get the more expesive one?
Old Jan 6, 2007 | 12:20 AM
SeNia_CLK's Avatar
2001 CLK 320
If you search this forum you will find an average price for the MAF. Unless you are in Canada then it will cost you about $30-40 more at the dealer.
Old Jan 30, 2007 | 07:35 PM
charnack's Avatar
2003 s430 4Matic
Just curious as to why you had to replace the Crank Shaft Positioning Sensor.
I've got a 94 e320 cabriolet. It just began having problems starting. It turns over but won't start. After a bit you can try it again and it works. The dealer is saying we need to replace the CSPS. Chris.
Old Jan 31, 2007 | 01:50 AM
AMGEEZY's Avatar
2001 CLK55
The CRANK Position Sensor is a common item. I have replaced that and my MAF on my CLK55. I have also had to replace both front wheel bearings. They both went out about 3 months apart. Those seem to be the 3 most common items.
Old Jan 31, 2007 | 02:58 AM
SeNia_CLK's Avatar
2001 CLK 320
Not sure if I metioned this but turns out it was my sparkplugs that had to be pulled and replaced! Problem solved
Old Feb 1, 2007 | 12:28 AM
Whodat's Avatar
Motor mounts going bad are common I'm hearing. I understand the symptoms are similar to a bad MAF. I haven't been a 'victim' of that one yet though.
Old Feb 1, 2007 | 01:54 AM
SeNia_CLK's Avatar
2001 CLK 320
Thats is actually what I've been told also...
Old Feb 14, 2007 | 11:35 PM
CLKonDUBS's Avatar
Piece of SH*T
Well I just changed my spark plugs and now I have a CEL (check engine light) I know I'm not stupid and I do have hands on mechanically wise and the only thing I did touch was the MAF,(intake), pulled the wires out disconnected the coil packs and removed old plugs and installed new plugs and put everything else back to where it was. Did they tell you why it ran a check engine light? And what caused the spark plugs to pull a CEL?
Old Feb 15, 2007 | 12:59 AM
MarcusF's Avatar
2002 CLK430
You may want to consider dumping the codes. I have to make some assumptions. (1) The car was running fine before you started. (2) You changed the plugs because of time and/or mileage and (3) only since that change has the CEL started burning a hole in your dash. If all that is true, then I think one of your spark plug wires is damaged.
Like it's name implies, a capacitive discharge ignition stores energy in a capacitor. When it receives the ignition signal from the ECU, the capacitive discharge ignition box then dumps that energy into a coil. Rather than building and storing energy in a magnetic field (old style coils do that), the coil simply ramps the voltage up as it passes the energy out of the secondary circuit and through the high-tension terminal. That energy is passed through the plug wire to the plug, which releases the energy when it fires. The ECU can determine if the energy hasn’t been released, because the CD box rats him (the current) out. If the energy isn’t released the ECU knows the plug didn’t fire. When that happens with any degree of regularity, the ECU illuminates the CEL.
This is assuming the engine doesn’t shudder like it running on seven cylinders. If that’s the case, I’d guess one of the coil packs aren’t plugged into the wiring harness.
It’s a wag, take it for what it’s worth.
Old Feb 15, 2007 | 03:28 AM
arthurx01's Avatar
2001 MBZ CLK 320
my CEL went on too, its my..
upstream O2 Sensors 2x -- 292 each.
air flow sensor -- 385
total + tax/labor -- 1208.94
can anyone find me a cheaper price?? or know a good place near rowland heights area?? 626.
thanks
Old Feb 15, 2007 | 02:42 PM
CLKonDUBS's Avatar
Piece of SH*T
Thanks Marcus! Come to find out it was the spark plug wires, it wasn't damaged but loose. Dumb part of me, I was rushing it and I did it at night in my garage so I was rushing to get it done for dinner and a movie night..you know how that goes! Thanks for the help!
Old Feb 15, 2007 | 03:58 PM
clkal's Avatar
01' CLK55
the 3 most common reasons for the check engine light to come up on our W208s is a faulty MAF, faulty crank postioning sensor, and the front/rear 02 sensors.
Old Feb 25, 2007 | 07:18 AM
Ted Baldwin's Avatar
300ce
...........Do yoy please know what the code said or the code number. Was it something to do with idle speed?
Ted
Old Feb 25, 2007 | 08:18 PM
CLKonDUBS's Avatar
Piece of SH*T
Ted
I actually didn't check the code as I didn't have time to read it since I was so anxious to find out the problem I just re-checked everything and that was the problem, a loose spark plug wire. BUT the codes for that I heard was like a misfire on certain cylinders on whichever one your having a problem on and that will run a CEL code and that's what I was probably running..a CEL for whatever cylinder that the wire was loose on. It didn't bother with Idling but it did turn on my engine fan when the engine wasn't even near warming/hot temperature..Hope this helps.
Old Feb 25, 2007 | 08:39 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Maf
The MAF will throw the codes P0170 and P0173 indicating fuel trim left/right banks, respectively. The MAF is about $200 shipped and I found mine on ebay. It is very, very easy to replace, comparable to say replacing your air filters. Please feel free to IM me and I'll help you out or you can call me - just IM me first. Also, the CPS or crank position sensor is replaced by many of 'us' as a preventative measure since the part simply fails without warning and is also fairly easy to replace. You'll need torx bits though. You need to buy a OBII reader with these cars, again they're like $40 on ebay. I have a C43 and can walk you through any questions you may have.
