Remote trunk lock not working on W208 (430CLK Cabriolet)
Can open trunk by inserting key in trunk lock,
but button on fob, and button on dash do not open trunk.
Some tech told me it is a vacuum switch.
Have a friend that had dealer fix his on a C class, $800.
Any repair help/tips would be appreciated.
also check and see if your rear defroster still works if your in a cold climate.
i have a simular issue and have been way to lazy to investigate a truck lock change. my conv top functions normally but the car thinks its not fully closed so it beeps and the light flashes...
Key remote operates door locks and alarm OK.
5 fuses in locking system.
Removed all, tested them for continuity--OK.
Re-installed all.
When I press trunk button on key remote, buzzing sound comes from trunk lock. Removed lock, pneumatic actuator extends when press either key remote, or console button Doesn't seem to be air problem.
Hit it with WD40, no help. Trunk still will not open with remote or console button.
If pneumatic, then what is purpose of two electric leads ?
See link:
http://www.panchogun.com/FVWebPhotos...Trunk-Lock.jpg
There is a switch sitting next to the locking mechanism on the trunk lid, looking like a light switch from a fridge. It has 2 functions, for one it controls the trunk light, but also signals if the trunk is open or closed. So in Hitmans case it seem that it could be an idea to check up on this one. Try to "open" this switch and see if your car think the trunk is closed.
See link:
I have seen that there should be steady light in the dash button if the trunk is open, if the system is ok. If it is flashing then it could still be the "Fridge Switch", not "closing" completely, but only just.
You convertible guys, maybe have one more switch, telling the system that the car is not opening or closing the top, and you should try to find that if the above does not help.
Light is solid red, no blinking, when trunk open.
The light/fridge button functions OK turning light on/off.
What else should I look at re. this light/fridge button ?
The actuator is connected to two yellow air lines.
Actuator extends and retracts (see image supra).
What else should I look at re. the actuator and lock ?
What should I look for re. the pump under trunk floor ?
(I always thought the pump was under the driver's seat.)
I would try to imitate the passive part of the locking of the trunk by pressing a rod into the grip of the locking mechanism, push the "fridge" switch and the see if I could pull the rod out from the grip of the lock. I hope you understand where I'm getting.
If this don't work, then I have to
give up and can only say it may be the locking mechanism, as the, unless the springs for pushing up and holding the trunklid have gone bad.
Good idea re. the rod test on the catch mechanism. Will try that when I get home from work tonight.
PS. Tech friend at the dealership let me into a bay after hours and hooked me up to the Star diagnostic, looked over the error codes, and cleared all the old ghost. He didn't mention the trunk, and I should have asked. Good Harley friend. Cool Star machine. Wish I had one. I think they are $10G or so. Should of had him look for trunk trouble. I've been living with this bad trunk so long that I forgot. I'm getting a knock off diagnostic multiplexer, have software, maybe this will help out.
My trunk issue showed nothing on the STAR diag. It was no help.
I still have my old defective trunk lock. I could send it to you if you're in experimental mode. Just let me know. Personally, at this point, I'd just change the trunk lock if I were you.
"Sorry been over at MBWorld and AMG Private Lounge...
The dealer repalced a faulty trunk sensor...the trunk wouldnt pop at times with remote or inside the cabin. They also replaced the cables for the top. When the top would start to open the front would slam back down and I had to hold it up to keep the bows in bent position for it to close...if you want to discuss further hit me up and I will respond...I have other items I would be happy to share as well...especially my AMG Euro springs...."
i am going to look at that fridge switch this afternoon if i dont get roped into something more exciting. would that cause the trunk light to stay on and toast the battery ?
I'm going to try it some time this week.
Would be a blast to get my trunk working again,
without having to give the dealer a bag of gold.
