Convertible top stops half way
Black 00 Cab here....
http://www.benzworld.org/forums/w208...2C+convertible
It's over on the 'other' forum. I strongly suggest reading. 2 guys have repaired their soft tops on their own. Palm Tree Mechanic also posted pics. The fluid resevoir location is shown on one of the pics. The culprits were a broken wire, the other was a bad wiring harness. BOTH issues were found under the decklid in an area that apparently is suspectible to bad wiring (maybe the opening and closing of the top contribute to the bad wiring).
Hope this helps!
I ended up taking it to the dealer and he has ordered a switch to correct the problem. It is due to come in today and if it is corrected I'll let you all know the outcome.
The other posts, with photos, was very informative, by the way, and it pays to read up on this. Everyone should be able to quickly raise the top manually, if necessary.
C
i went to put down the top yesterday and after the soft top was safely stowed away the rear deck lid stopped closing, i tried to manally close it and it would not latch, after manually sliding the lock i was able to physically close and latch it.
now for my good luck to click in, i had the top down again this morning, when closing it the same thing happened the rear truck lid wouldnt close. the rear half of the soft top had not yet "curled" up to allow the rear lid to close so i lifted it up and tried to close the lid manually. it must have unclicked because i had to push the soft top into the latch below the rear window and it got stuck mid way. after some gentle hacking with a screw driver to make the lock pull the top closer down i tried to use the conv switch to finish the motion didnt happen, i pushed the headrest button down and the lock grabbed and shut. Now the top is no longer functional. Outstanding.
That's it. Mine was broken internally. The latch has to be open for the top to work up or down. When you open the latch opens for the bow to come up. The left switch activates it to stay open. Mine was closing, the latch was broken internally and had to be replaced.
The left swith is $75 wholesale(internet) $98 list. The latch is $350 wholesale(internet), $450 list. To change it out, you have to be able to plug the hydraulic hoses (mb plugs or golf tees).
C
i am going to investigate the lock switch again tomorrow... if it stops raining
i dont want to throw money at every part...
