20s + h&r cup kit + W210 #1 pads = rubbing?
Tire sizes you will need to ensure that you will not rub. And if you do rub it won't be that bad. Hope this helps.
Falken
225/30/20
245/30/20
Falken
225/30/20
245/30/20
n are urs the ZE512s by ne chance too?
You might want to try:
#3 pad - front
#4 pad - back
And if you rub with this set up with the cup kit go with a #1 pad on the bottom all around to lift it...that's what I had to do with cut springs and it rides good. I might end up going with a #2 pad all around because I still rub a little on the back driver side...but I always have had a problem with that side because for some reason my fender has never been even with the other side.
I will let you know if I do it this weekend and I will sell you my #1 pads so you can have them handy to install on the bottom in case you rub with what ever set up you go with.
as long as its safe for fast speeds and all...im kool wit it...it shud b rite?
