Clk430 won't start.
Old May 9, 2007 | 12:26 PM
Netgato's Avatar
Clk430 won't start.
Help, My 99 Clk430 won’t start, it turns but it won’t fire.
Tune up about a year ago new filters, gas and air , spark plugs, etc.
107,000 miles. I need some help.
Thanks.
Old May 9, 2007 | 01:40 PM
Whodat's Avatar
2000 CLK 430 Cabriolet
Thanks.
When did this happen? First thing in the morning or after you'd driven it around for awhile?
Old May 9, 2007 | 01:56 PM
Netgato's Avatar
First thing in the morning.
Old May 9, 2007 | 02:02 PM
lawrdent's Avatar
clk 430 cabriolet
Had the same problem that you have about a year ago. On my car it was the MAF sensor. Had it replaced.....unfortunately did not know about this forum at the time and could of done the work myself.
Old May 9, 2007 | 02:23 PM
DropTop208's Avatar
02 CLK 430 Cab
Does it keep crancking or does it cranck for a second or two and stop?
Old May 9, 2007 | 02:28 PM
Netgato's Avatar
It keeps cranking
Old May 9, 2007 | 02:34 PM
DropTop208's Avatar
02 CLK 430 Cab
I had a problem with mine where it would crank for a second and stop, it was a low battery causing it. You could have a bad crank sensor.
Old May 9, 2007 | 02:53 PM
scottster77's Avatar
CLK320, Honda Ruckus, pinto & BMX
mines was the crank sensor... it wouldn't start at times.. then finally within weeks.. it was gone.. got it replaced and its fine now..
Old May 11, 2007 | 10:34 PM
krayzie_e99's Avatar
2000 CLK 320
its definately sounds like the crank positioning sensor. i bought mine online and installed myself for around 80 buks. there are dyi, just do a search. good luck !
Old May 18, 2007 | 11:35 PM
Netgato's Avatar
Thank you, thank you, thank you.
It was the crank sensor.
Car is running great again...
Old May 21, 2007 | 11:41 PM
Whodat's Avatar
Good deal.
Damn these CPSs fail even when the car is cold? That's a new one on me.
Old May 22, 2007 | 11:40 AM
acb3nz's Avatar
Custom CLK / 05 E500 4matic / 04 Acura TL <<Daily
Is either your alternator or battery. I'm leaning more to be a battery issue sinse it has happen to me, i end up buying a new battery and it fix the problem.
