Driver's Seat Motor Repair
They burned at least once before and now everything else works -- seat back reclines, etc -- it's just forward/back that doesn't work, so I'm thinking it's the motor.
Was this at the dealer's parts department or did you have to wait for him to order it? My CLK is parked waiting for me to fix it... I was thinking of taking it in but if it's a 15 minute job then I'll just get the part and do it myself.
-- edit --
I'm on the same boat because my wife is driving it and I'm driving my G35, so it's not urgent. Otherwise I probably would have taken it to the dealer.
Not sure that it's worth 3-4 hours worth of labor though, but either way keep everyone posted. I'm sure we're not the only ones that are gonna run into this.
Thanks for the Mercedes Parts Superstore tip. I'd never been to that site before.
Looks like it would be a lot easier if I could remove the whole seat, but that in itself looks like a chore. I would imagine it's an hour's worth of work or so, plus the part... if the dealership was reasonable I wouldn't mind, but they're saying 4 hours labor + $135 in parts, where it's a $65 part online and takes an hour to do (hopefully).
Let's see where this goes...
Old motor is out, new one is in. Works like a charm. I seriously recommend that you don't mess with this unless you don't mind working in cramped spaces in strange twisted positions. But if you feel like spending an hour or two of your Saturday and saving $600+, be my guest.
You can get the part -- 208 820 08 42 from the super store for $65. Or you can pick it up from the dealer (mine had it in stock even) for $134 + tax.
The front/aft motor is the middle one -- of course, the hardest one to get to -- out of the 3 under the seat. The other two are 12 42 instead of 08 42.
The absolute hardest part is getting to the bottom torx under the motor (there's a shaft blocking the easiest path of course)... but once you're in there it's all good. I suggest a really thin screwdriver if possible, although I have a reasonably thin power screwdriver (Black and Decker) that worked even though I had to jam it in there to get to the bottom screw. That helps a ton because the screws are LONG, so getting them out manually takes some effort. The box with the connectors needs some pushing around but it moves relatively easily so again it's not a big deal.
Definitely watch out for the little shaft extending INTO the motor when you take the old one out though. Doesn't look that flimsy but it's small and you need to look out. And btw the connector is easy to find but you'll have to cut some zip ties which should probably be replaced after you're done...
So that's it... one bruised knuckle and a lot of sweat, but I wouldn't hesitate to do it again if I had to, now that I know how.
My passenger seat is stuck from moving forward and back. The other 2 motors work. Do you recommend moving the seat as high as possible to get better clearance? I can do that with one of the two power buttons that still work. Also, has anyone considered swapping the good motor from the seat that works with the one that doesn't to see if it really is that motor?
I'm thinking about swapping the driver's side with the passenger (broken) to be sure. Anyone do this?
If you feel like getting your hands dirty and cramping yourself under the seat and saving some dough, you can do it yourself.
If my dealer had quoted me $250 instead of $600, I probably would have done it and called it a day. But with that said, now that I know how to do it, if/when the passenger side goes, I'll probably do it myself again.
Thanx for the info
