Touch up paint part numbers
2004 E55 AMG
Hey all,
I've been trying to find out the part number for the OEM Mercedes Benz touch up paint but I haven't had any luck so far.
The color I'm looking for is 040 Black.
If anyone has a bottle of this touch up paint or any other color touch up paint can you please post up the part numbers for future reference?
Thanks!
Thanks!
2004 E55 AMG
www.paintscratch.com is also a good site to find touch up paint.
The only issue I've found is that when you buy the touch up paint from these sites they require you to use a base coat, clearcoat, and primer.
That's the reason why I'm looking for the OEM touch up paint, I believe it's a one-step process so it should be much easier to use.
If you have a scratch down to the metal, you will have to put a primer on even if the paint is OEM. If there is no metal showing, you can use these paints like OEM. The OEM kits from the dealership have a clear coat with them. You can get clear coat at any car parts store.
2004 E55 AMG
Found it on google.
I haven't confirmed it yet, the description for that part number shows up as "PAINT PIN" so if anyone actually has a bottle of the stuff can you please confirm that it is indeed 040 black?
Also, I came across some information that says 040 black is not supposed to have a clearcoat. Only the metallic paint codes are clearcoated.
![Post](https://mbworld.org/forums/images/icons/icon1.gif)
As you can see here:http://eshop.original-teile.de/Listen/allparts140.pdf you will have to guess which the first digit is. A hint is that the final three are those of your color code.
So I'd guess the black 040 requested would be 9040.
A little late now, I know. But for those of you googling this...
