CLK32 is it possible???
Old Nov 5, 2002 | 01:48 PM
3 bAn 2 PoW 0's Avatar
CLk320
I was wondering if CLK320 have the same engine as the C32 & SLK32? if they do could it be possible to take a C32 or SLK32's supercharger and put it in a CLK320?
Old Nov 5, 2002 | 03:12 PM
Mach430's Avatar
The engines are the same size, however not internally. For the money, you would be much better off with a Kleemann Supercharger. The cost to fabricate and test all the necessary parts to make the inferior AMG SC work on the 320 wouldn't be worth it.
Old Nov 5, 2002 | 03:15 PM
bmac002's Avatar
CLK 320
I posed this question to Renntech a long time ago. The response was that Renntech could do the conversion. It would cost approx $24,000. The supercharger is not just bolted on to a standard 320 engine. It has different compression (among other things) which would require different pistons (not exactly engine inclinded help?). I have a feeling that Renntech's low boost supercharger kit is almost the same as the 32 engine? It might be cheaper for them to just fit a 32 engine in a CLK. Also, why use the AMG supercharger when Kleeman will give you 330hp!
Old Nov 5, 2002 | 03:39 PM
Mark D.'s Avatar
i actually have a supercharger from an slk32 if you want to try something...if you want it...give me an offer
Old Nov 6, 2002 | 12:20 AM
Brian_R170's Avatar
'02 SLK32 AMG
In a recent issue of Car & Driver, they featured a RENNtech SLK38K, which was an SLK320 that was modified by increasing the displacement to 3.8L and adding the AMG supercharger, computer, etc. The engine put out about 440hp, but the car also had wheels, suspension, brakes, body kit, and transmission mods. The cost of the car was about $112,000, which means the mods cost at least $60K. Probably close to $40K on the engine.
Unfortunately, the bad thing was that the car was still not quicker than a stock SLK32 AMG. It probably would have been cheaper to just throw in all of the SLK32 components (engine, transmission, differential, brakes, etc.)
If you're serious about it, you really should consider the Kleemann kit instead.
Old Nov 6, 2002 | 12:21 AM
LowRydeR's Avatar
just sell your car and get the slk32 amg.
-Bruce
Old Nov 6, 2002 | 02:25 AM
Bjorn's Avatar
CLK
ok.. kind of confused... but how can a car putting down 440hp still be slower than the slk32AMG having 349 hp...
-B
Old Nov 6, 2002 | 04:53 AM
vodc4's Avatar
i think horsepower alone does not justify the performance...
i think it's also got to do with the transmisiion, gear ratio...i dont know...
Old Nov 6, 2002 | 01:27 PM
Brian_R170's Avatar
'02 SLK32 AMG
-B
The axle ratios were different, also the RENNtech SLK38K had a beefed-up Mercedes 6-speed manual instead of the AMG Speedshift automatic.
RENNtech's response was that the test-driver from Car & Driver had too much wheelspin on launch, although you'd think they would have done a few runs.
Old Nov 6, 2002 | 02:13 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
because the AMG gives you 349hps !!....hehe
Old Nov 6, 2002 | 04:04 PM
Mach430's Avatar
The AMG SC on the C32 gives more power than the Kleemann C320 (which btw posts an average gain, we've seen higer) because the motor is built specifically for the SC, and runs higher boost. At the same boost, the Kleemann would easily make more power than AMG. Kleemann has been supercharging Mercedes for about a decade longer than AMG, and is in many cases a role model to them.
Old Nov 6, 2002 | 09:26 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
if the kleeman kompressors run at the same boost as the AMG's they would indeed put out more power, but at the same time they will need extensive mods to the engine as well. The result might cost even more than a C32, as kleeman's kompressors are not cheap at all.
Old Nov 7, 2002 | 02:08 AM
CLk320
is it possible to do a engine swap then like to a C32 engine?
anyone know how much will that cost? good thing to do or not?
Old Nov 7, 2002 | 03:28 AM
Mach430's Avatar
For the money, you will be best off with a Kleemann.
Old Nov 7, 2002 | 04:45 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yep, if ur talking about after market mods. If ur talking about getting a brand new car, do some math first, and see if the C320 with kleeman will be cheaper. if so, get the kleeman, if not, then get the c32 from factory.
Old Nov 9, 2002 | 04:21 AM
CLk320
THanks for all the info everyone!!
