19" Wheels Fitment
19" Wheels Fitment
Does anybody have the following wheel sizes?
19X8.5 E.T 45 Front
19x10 E.T 45 Rear
Do they fit with no rubbing problems? Any spacers needed?
Your comments will be appreciated. Thanks
19X8.5 E.T 45 Front
19x10 E.T 45 Rear
1 Post
2000 CLK 3.2
You're going to need spacers up front and in back if you want those wheels to look right and not rub on the inside.
At least a 10mm hubcentric spacer for the front
and for sure a 10mm or 15mm hubcentric spacer for the rears depending on how aggressive you want the rear to look..
Make sure they're hub centric and wheel centric to the center bore of the wheels so you don't shake around.
SL55, C63
and, as CLKFAN stated above, if you want your rim to be more flush with your fender, you will probably need to use a 15 mm spacer.
make sure you use hubcentric spacers and not those cheap $5 china ones.
+1...youre prob gunna need a spacer as i was rubbing even with my 18x10 rears whenever i hit a hump in the road and especially when i had passengers..."No fat *****es - car will scrape"...i really needed that lil decal lol
I am gonna find another set of wheels with correct offset , i do not like to have spacers on my car.
OPALW208, what is the offset on your "20? Do you experince any rubbings?
SL55, C63
it's a custom offset. VIP Modular does NOT reveal their offsets to the public.
With 3 piece rims, typically the manufacturers do not like to give out that info. It really depends on the curvature of the spokes of the wheel which is called the "X-factor."
