How to get wheel off?
Old Jan 11, 2008 | 09:34 AM
06C55AMG's Avatar
I'm in the process of putting on winter tires/rims on my 2006 CLK350 and I had the car jacked up and the lug nuts off but the wheel will not come off? Anyone have any experience here, thanks.
Old Jan 11, 2008 | 10:36 AM
DESAL's Avatar
GLC SUV 350e4 Verde Silver Metallic
Had similar
Don't have your car but in the past when that type of thing happens my experience has been that the brake dust (rust too if it is old enough)has "cemented" the parts together. So what I did was hit the rim inside and outside all around with a RUBBER mallet. What I was trying to do was break the seal. Good luck.. I’m sure you will get others to join in with there experiences.
Old Jan 11, 2008 | 12:46 PM
RobertG's Avatar
things with and without wheels
Lossen the lug nuts till there are finger loose, lower the car and drive it slowly making a bunch of turns, this should get it unstuck.
Old Jan 12, 2008 | 04:55 PM
deyainrdy4ds's Avatar
w208
kick it
Old Jan 12, 2008 | 10:35 PM
The Jury's Avatar
2002 c240
LMFAO for the love of god don't do that,..... some are likely to try it.
OP: I take it you've not spent too much time around a tire store? I've bought tires every 6 months for my car because I live on a mountain and I take full use of it so I have spent many trips watching my tires being changed. It's almost always a given the wheel will stick a little. You can either kick the corners of the tire to break it loose or you can grab it from the back on each side and try to wiggle it free from the rotor assembly.
Old Jan 13, 2008 | 12:57 PM
CLKonDUBS's Avatar
Piece of SH*T
Originally Posted by deyainrdy4ds
kick it
Old Jan 13, 2008 | 01:14 PM
RobertG's Avatar
Wow you replace tires every 6 months!
Why not just buy new tires.
Old Jan 13, 2008 | 02:12 PM
John 99CLK430's Avatar
1999 CLK430 (sold) 03 CL55
kick it
+2 had same problem when I was getting my new tires, just kick it all around the tire/wheel and it'll come loose.
Old Jan 13, 2008 | 06:39 PM
BAYCLK's Avatar
2002 CLK320
I just changed my tires too...Just give it some good kicks and it will come off! The Rubber hammer works too!
Old Jan 14, 2008 | 08:59 AM
RobertG's Avatar
and what do you do after kicking it still doesnt get the wheel off ?
Old Jan 14, 2008 | 09:53 AM
Holson's Avatar
18 G550, 24 EQB3504M
I watched a AAA guy do:
1) Loosen a few bolts/nuts
2) Lowered the car
3) Raised it back up
That was it - it was my friend's car and we had tried kicking the living sh!* out of it.
Old Jan 14, 2008 | 12:53 PM
Well then you could try the suggestion Holson just made, but the wheel does come off after kicking it a few if not a bunch, it's not gonna be stuck on there forever now...
When my tires were being changed, all came right off except the front passenger tire, kept kicking it, then got to the point where the rubber mallet was used then kicked the tire from the inside a bit, spin the wheel, kick, spin, kick. and Vola.
Old Jan 14, 2008 | 03:21 PM
RobertG's Avatar
Well I'm glad that the wheel came off for you that time, I was asking a question along the lines if it didnt come-off while trying to kick it or using a rubber mallet. My suggestion in post #3 was aimed at this type of a problem.
Mr. Jury thinks that is a bad idea, then he did not spend enough time at those tire shops to witness things like that.
If his so called tire shop actually cared for him then they would apply antiseize lube to the mating surface of the rim and the hub and he would never have that problem again.
Old Jan 14, 2008 | 03:24 PM
AMGfan's Avatar
06 SL65 / 97 993tt /11 Suburban/ 2012 GTR (AMG è la mia Famiglia la Bestia è la mia protezione)
PS
Invest in a floor jack and a torque wrench with sleeves to protect the interior part of the wheel where the lug nut rests. Rubber mallet work for me, too.
Jon
