MB says 6qts in the tranny, confirm?
I have a leak on my tranny pan seal. I purchased a new filter, seal, and 6 qts of MB tranny fluid. The parts guy said as long as the TC is not being pumped clean, 6 qts is the amount I need.
I know a few folks have done a fluid change here, so I was looking to get confirmation of how many qts you used.
CLK430
TKS
CLK430
TKS
According to them 8 qts would have been around the amount for draining the TC as mentioned above. That'd be a full drain and flush. Simple drain and refill should be 6 qts, if anyone here can chime in that has done the change. I know a few people did it. Without a TC flush, that should keep over a qt in the TC. Maybe the proper question is how much does the TC hold?
I hope it's only 4..... I paid $16 a qt for that shat! I'll take two back!
Unfortunately I sprang a leak at the pan gasket and it needed to be done NOW so I had to run to the stealer for the parts ($238, gasket, filter fluid). I didn't have time for waiting on the net to ship. I lost a good bit of fluid over a 2 day period, to the point it was misshifting in hard turns when I'd throw the fluid up the side of the pan.
It's only been 2 days, and I'm going in to have it changed out in ....... 2 hours and 45 mins from now.
We'll see what it drinks.
You have to buy the special dipstick from MB.
I paid $45 for mine at the stealer
You DO NOT need the cap ($5) or grommet ($2) if they try to sell you one.
All you need to replace is the red locking piece when you pop the old cap out.
It's time for a new set of air filters, that is going to be a PITA alone after the week I have had. (new brakes, tranny fluid, filter, gasket, 4 new tires, labor for each)
After I buy the filters ($80-ish) I can concentrate on the $300 for spark plugs.
I need to look into this further before I get the tuneup on mine underway..
Holy crap.. are they like $12.00 each!??!?!? That's almost as bad as a motorcycle! Check out sparkplugsonline.com or something like that. A couple years ago I need plugs for my Ducati ($18.00 each at the dealer). I found them online for $2.50 each. THE SAME PLUG.. made by Champion.. they just did not have the Ducati logo. I suspect the plugs can be found a lot cheaper.. maybe not
I definitely gotta look around, I think I remember seeing somwhere on here something about what spark plugs people use, I guess I should just do a search like we always tell the newbies to do! I have a couple of days to find whats good to use!
Wow, $12 for a spark plug! Thats crazy!
Part Number Description
4418 PLATINUM+4
4301 PLATINUM+2
4501 PLATINUM IR FUSION
7422 OEPLUG GAP=0.040"
4418 PLATINUM+4
4301 PLATINUM+2
If you wanna put those s**ty platinum $5 plugs in your benzo, go for it. I'm running the best I can for my car which is why I bought $16 each tranny fluid from the dealer rather than ATF from autozone. I had about $100 in 6 qts of tranny fluid. Sure I can shop online and find it cheaper, but the circumstances didn't allow, point being I didn't go for cheap sh*t. I'll withhold any comments about what is the same and what is not, just know "I" do not skimp.
Marcus I need to do the MBCA thing..... Just haven't had a chance.
