NEED HELP with CLK Engine !!!
Old Jan 18, 2008 | 04:06 PM
gregory13lil's Avatar
2000 CLK430
Well I have pretty much been problem free so I knew that I would soon have issues like all the rest of thw 208's.
Here is my issue....
When I start my car in the morning and the car is of course cold I get almost no power. If I try to take off hard it just bogs down like its not getting enough fuel or something. But as soon as the car warms up it starts taking off like normal except it takes a couple of seconds to (Wind up) and then it takes off but with less power than it normally has before this issue started.
These are the items that have already been replaced in the past couple of months:
New NGK Iridium plugs
New Air filter
New Fuel Filter
New motor mounts
Cleaned MAF sensor 3 months ago when I changed out the plugs. I used the autozone MAF sensor cleaner.
I am almost guessing that it could be my MAF but hoping it is something cheaper!!! It has to something that is controlled by the engine temperature since it is not working well when the engine is cold.
Any suggestions??
Greg
Old Jan 19, 2008 | 12:08 AM
MarcusF's Avatar
2002 CLK430
Is the air cleaner assembly properly seated? The engine will bog if there's a gap.
Old Jan 19, 2008 | 03:50 PM
2000 CLK430
I will recheck the air sealer for any gaps hopefully thats it...would that cause it to bog only when cold?
Old Jan 20, 2008 | 01:43 AM
Focus on this 1's Avatar
Clk 55 04
Why dont u try cleaning your injectors?
Old Jan 21, 2008 | 01:17 PM
2000 CLK430
The air cleaner was sealed properly to the MAF so I am going to try the fuel injector cleaner today. What brand is the best to buy or should I have this professionally done???
Greg
Old Feb 7, 2008 | 10:16 PM
2000 CLK430
Ok..I really do need some help now before I am forced to turn this freakin car in to a mechanic.
Ok I am still having the same issues as stated above except that now it hesitates at tale off now as well. It feels like it is going to die at take off for about 2-3 seconds and then it just kicks in and takes off, and this is with just a little bit of gas.
I have just replaced the whole MAF Mass Air Flow Sensor and rechecked all the connections. I am still not getting any errors on the dash or any CEL lights at all.
I do have some concerns about a sound that is coming from my exhaust...it sounds like there is some thin aluminum rattling. It could be my Catalytic converter. If it is my CAT then could this be causing my hesitation problem or is this just an extra thing that just happened to go out on the car as well??
And once again, ANY Help is appreciated.
Greg
Old Feb 7, 2008 | 10:50 PM
riannausa's Avatar
2001 CLK430 & 2007 350Z
Exclamation hi
Sorry to bug but how do you clean the Fuel Injectors?
Old Feb 7, 2008 | 10:54 PM
2000 CLK430
I just did what many others recommended and that was to buy a bottle of good quality fuel injector cleaner and then I drove around pretty much the whole day.
Greg
Old Feb 7, 2008 | 10:55 PM
2000 CLK430
I have been doing some more reading and I feel that it could be the ceramic that is falling apart in one of my CATS is periidocally blocking my exhaust thereby increasing the backpressure. I am confused after chasing this problem all this time now.
Old Feb 8, 2008 | 12:27 AM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
sorry to hear continued bad news, greg. i believe rattling does typically imply cats. unfortunately they're not too cheap. i'd have a muffler shop listen to it and check it to see if they think it's the cats. it would definitely be cheaper than the dealership, and they should know a bad cat if anyone does.
Old Feb 8, 2008 | 12:31 AM
rocko's Avatar
06 S55 AMG
Hey Greg! Thanks again for the part...my car also recently had the same problem with the rattling sound...whats your mileage? Please tell me its less than 80,000..If so, take it to the closest Mercedes dealership and they will replace this for you under warranty. Fletcher Jones did it on mine @ 79,900...lol...anyway, as far as the hesitation, I did not experience this when my cats were going bad. Hope everything works out for you.
Old Feb 8, 2008 | 11:43 PM
2000 CLK430
Well I dont know if anyone really cares but I will let everyone know anyway that I found the problem!!
My MAF was bad after all!! I ended up replacing it last night but didnt hook up the cable all the way. It ended up giving me the CEL light telling me the MAF was bad so I ended up checking the connection again and tightened it and now I have POWER that I hadnt seen in at least a year!! I am in love with the car again!!
LATERS
Old Feb 10, 2008 | 11:45 PM
SoCalw11w123's Avatar
well done!
Old Feb 11, 2008 | 01:19 AM
The Jury's Avatar
2002 c240
As I was reading down the thread I kept saying "that is absolutely a MAF", but as I read I saw you say you replaced it and I thought "No it has to be a MAF... those are the maf signature trademarks".... then I saw the last post
Glad to hear you got it done I actually imported a MAF from Germany for $87 last year when mine went bad.
Old Feb 11, 2008 | 08:09 AM
2000 CLK430
I am getting to 107,000 so the CAT fix is going to be all on me. I am in no rush to fix the CAT until it gets a little worse. My main concern was the hesitation problem.
Oh and were you able to get that light off that you were talking about?
Greg
Old Feb 11, 2008 | 08:12 AM
2000 CLK430
And thats why I bought a MAF because it sounded like it but when I replaced it (loose LOL) it didnt work but got worse then I started worrying. I was about to start pulling plugs to check for bad ones when I decided to push the connection in a little tighter and BAM it works now.
MORALE of the story TAKE YOUR DAMN TIME EVEN WHEN YOU ARE TIRED..or wait a day!!
GREG
