Opinions on paint......
Here is the way my car looks now (black/chrome grill w/ flat hood emblem)
I was thinking about blacking out the lower area in the bumper between the fog lights to help set off the grill.
But I don't think painting the piece would be to be your liking, you'll eventually kick yourself after you finish it. I think a mesh on the other hand is worth considering the effort to put in.
There is a thing called "flow" and when you black parts out it breaks up the flow. It makes the parts stand out like a sore thumb. On muscle cars it can be a good thing, but on a sleek Mercedes that is designed to flow smoothly it is a bad thing.
IMO the three slot grill doesn't look all that hot. It's misproportioned to the rest of the front end that has smaller lines. a 4 slot, or better, would be a more proportioned fit. Since you already have it though, I'd recommend colormatching the slats and leaving the emblem and the black fill around it (inside the circle) as it is.
The black grill does not look good. It stands out too much and breaks up the flow of the front end. In short, it's fugly. Making the slat on bottom black also is even more fugly. Talk about standing out in a bad way........
Hopefully you'll see this as constructive.
Next mod I'd go with either the euro projectors or the cheese graders. I chose the euro HID factory projectors. Makes a nice difference.
Here's a pic of them installed, I'll go find the details side by side pics from the swap............... Much better than the halogens. The obvious difference is a clear front lens rather than a serrated lens with grooves. The projectors are behind the inner lens so they are not visible.
I think I'll order up that top grill in silver.
