Leaking cabriolet (convertible top) / door seal in rain
Old Feb 25, 2008 | 09:00 PM
Flot's Avatar
01 CLK 320 Cabriolet
Car: 2001 CLK 320 Cabriolet
I have an annoying leak in the convertible I just bought - seems to be in the middle of the passenger side window, near where the convertible top seal is "hinged" to let it fold but I am not sure if the leak is at the seam itself.
Anyone have suggestions on the best way to tackle this? Visually I don't see anything particularly wrong with it, and the window seems to close tight against the seal. But I am getting a slight drip into the car under almost any rainy situation - not good coming into a south florida summer...
Old Mar 6, 2008 | 06:45 PM
Flot's Avatar
Hmm, apparently it was worse than I thought - had a real downpour today and seems like as much rain was inside as there was out. No advice for me??
Old Mar 6, 2008 | 09:54 PM
creekdog_A's Avatar
c32
I'm sorry to say but it is probably best to have a dealer to install a softop seal if it is needed because the window will have to be re-adjusted and there are several ways it can move.If it is not adjusted properly then it could cause a worse water leak or wind noise. But you may not need a seal maybe just a window adjustment.
Old Mar 7, 2008 | 11:01 AM
Flot's Avatar
I'm not much for letting a dealer touch any of my cars.
Any insight into the window adjustment? As far as I can tell, the window seals are in relatively good condition. Certainly no rips/tears and the rubber is smooth and fairly plyable. I was thinking about taking the door panel off this weekend and having a look at the window mechanism - I presume I can adjust it to make the the window fit "tighter" against the seal?
Old Sep 25, 2010 | 09:04 PM
dreamstrider's Avatar
CLK 99 Cabriolet
Hi.I know the thread is old but I have the same problem. Have you managed to solve it?
Old Apr 2, 2011 | 08:49 PM
Bt1965's Avatar
CLK 320
Same here, any comments?
Old Apr 6, 2011 | 05:50 PM
sstylos's Avatar
W208
I had the same problem.
In my case , I had problem only when the rain was really heavy.
Water passes through the fabric and then the inner coat.
It does not leak through the glasses-seals, in my case.
To see if this is your case too on heavy rain, check if the inner fabric is wet. Check both sides (passengers, drivers) as for a strange reason leaks only from one random side each time.
A good spray water sealer for cabrio cars will solve the prolem(eg Wurth).
They told me it lasts about a year.
Regards
Stelios
Old Apr 6, 2011 | 06:06 PM
sstylos's Avatar
W208
AAaahhh, I forgot to say that if the problem is at glass and rubber sealer,
then some Vaseline will stop it.
Rubber absorbs Vaseline and increase the mass of the rubber sealer.
Don't put to much, as doors they may not close, if you put tons of Vaseline.
Regards
Stelios
Old Apr 6, 2011 | 06:10 PM
Bt1965's Avatar
CLK 320
Regards
Stelios
Excellent! Thanks. In my case is both. In heavy rain, it goes through the fabric and in any rain through the top seal on the windows.
