How to recondition leather seats?!?!
Old Apr 22, 2008 | 10:44 PM
CLK430Benz's Avatar
2010 C300 4MATIC
Hey,
I have a water stain on my CLK430 Passenger seat. What would be the best approach to remove it. Also, what should i use to recondition my leather?
Steve
Old Apr 22, 2008 | 10:45 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
https://mbworld.org/forums/detailing-automotive-care-37/
Old May 17, 2008 | 05:55 AM
jreddyroc's Avatar
2002 clk 430
cleanig leather
top notch detailing places use some kind of chemical stuff spray it on and then they actually use a brush and scrub the leather then the wipe it down and its like new then use some conditioner on it so it protects from sun meguires is a really good conditioner top notch
Old May 17, 2008 | 08:11 AM
deyainrdy4ds's Avatar
w208
they mite have somethin u cud use
http://www.leatherique.com/price_list.htm
Old May 17, 2008 | 03:58 PM
Jays_Z's Avatar
How did you get the water stain. Take care of that first before you fix the seats.
Old May 18, 2008 | 01:09 PM
CLK430Benz's Avatar
2010 C300 4MATIC
I purchased the car used. Since it was a massachusetts car people that owned it before probably didn't care about the car. As a result, when it snowed, I guess when the previous owner got into their car with a wet jacket they damaged the seats.
Old May 19, 2008 | 10:38 AM
High Technology's Avatar
2020 GLC300 & 2009 SL550 (previously had 1999 CLK / 2006 E500 / 2011 GL450)
Originally Posted by CLK430Benz
Hey,
Steve
As with all things detailing, the first rule is to start with the least aggressive approach and work your way up if the less aggresive approach doesn't work. The second rule is to never put a protectant over something you need/want to fix first (i.e., clean first, protect second). When I detail my car, the prep (wash, clay, polish) takes a few hours and the actual exterior sealent takes 20 minutes. Same for the interior -- cleaning/correcting takes time, protecting is much less time consuming.
Back on topic, the CLK seats are made of some pretty resilient leather. Mine are nearly 10 years old and my car has 140k on it (all driven by my wife or myself). I have cleaned/conditioned them maybe 6 times in total. My seats look near-new, just some minor wrinkles on the side bolsters. So you want to be respectful that this is leather (and not vinyl), but you don't need to buy a specialty boutique product to do the job.
I would start with a mild leather cleaner, such as the Lexol Cleaner (I think it is the blue bottle). Just apply a few thin coats rather than one heavy coat if you have perforated seats (to avoid saturating the pinholes to the extent that you can). If Lexol Cleaner works, great. If it is just a water spot, then it should come off easily. If it doesn't work after two attempts since some stains take a second treatment, move on to something stronger.
Some of the pro detailers use a DILUTED Woolite solution to clean leather (yes, Woolite on leather). I am not crazy about using that on leather, because Woolite is formulated to be rinsed clean with lots of water, which isn't practical for your seats (especially if they are perforated like mine).
Old May 19, 2008 | 11:49 AM
2PHAST's Avatar
500E Signal Rot
I would steer clear of Lexol Leather care products, they are not tested well and on some makes of cars, will actually remove the leather dye.
One of the best leather restoration products on the market is made my Griot, the standard leather care product has a cleaner in it and the restoration product does not. www.griots.com
