Lower Control Arm Bushings
My service advisor said that this is causing my vibrations between 55-70mph. Lol! He advised me to look around because he cannot lower the labor cost.
Anyway, thanks again!
I'm going to replace the lower ball joints and outer tierods this weekend. The rubber boot for the ball joint is completely flat and so are the tie rod end boots.
Are your bushings cracking? Mine look fine.
https://mbworld.org/forums/c36-amg-c43-amg-w202/117233-has-anyone-changed-their-lower-control-arm-bushings-themselves.html
LPD's current Ebay listing:
http://cgi.ebay.com/ebaymotors/Merce...8003QQtcZphoto
I had the stock bushings changed out on my CLK55 with polyurethane bushings and the little shimmy was eliminated!
FWIW - I have no connection with LPD - just that their product has worked fabulously on my CLK55. Even their customer service is good....when I tracked my car in September, one of the bushings failed and after pics were sent to them documenting what happened, they promptly sent a replacement bushing at n/c. Since then, I've tracked the car 2 more times and no issues.
Good luck.
