lowering gurus?
Old Jul 10, 2008 | 02:11 AM
ZEEK's Avatar
Yo Momma
lowering gurus?
Hey guys, i know this question has been asked many many times but my question is slightly different. I dont want to change my stock springs to lower my car because of great highways and streets we have in nyc But i do however want a little drop, by changing #1 pads all around, do you guys think i will notice a drop? And by searching on the board i came up that #1 (9mm) for front and 17 mm for rear are the thinnest pads correct? So will i really notice a drop or not? Also i am going in for an alignment so i thought i can get the pads changed as well. what do you guys say?
Old Jul 10, 2008 | 05:39 AM
J56BP's Avatar
2002 CLK 430
front #1(9mm)
real #1(13mm)
goes up by 4mm
Old Jul 10, 2008 | 12:15 PM
deyainrdy4ds's Avatar
w208
use #1 w210 e class pads..theyre smaller..i believe 5mm
Old Jul 10, 2008 | 05:21 PM
CLK FAN's Avatar
2000 CLK 3.2
take the pads out all around for a drop
or get the #1 pads for the Eclass w210 like Hersh
said
Old Jul 10, 2008 | 06:21 PM
ZEEK's Avatar
Yo Momma
thanks guys, so if i get the #1 e class w210 pads all around will i notice a drop? or by taking out the pads completely will give me a more noticable drop?
Old Jul 10, 2008 | 07:16 PM
CLK FAN's Avatar
2000 CLK 3.2
no pads will give you a more noticeable drop but most people are chickens about doing that so just get the #1 pads and call it day.
Old Jul 10, 2008 | 08:00 PM
tnb1786's Avatar
SS Minnow Johnson
i dumped my **** with pads still. but im running 1's all around go to the clk sticky for pics last page tell if thats were u want ur car sitting
Old Jul 11, 2008 | 03:57 AM
ZEEK's Avatar
Yo Momma
Why would they be chicken about it? is it because it can damage the springs or your car's suspension or something? I would be chicken about it if it will damage something but if its giving me a nice little noticable drop to fill that little gap that i have between my 19s and fenders then ill go for it.
Old Jul 11, 2008 | 11:47 AM
CLK FAN's Avatar
2000 CLK 3.2
no damage...just chickens
Old Jul 11, 2008 | 03:30 PM
ZEEK's Avatar
Yo Momma
hahahah then i am just going to take the pads out.
Old Jul 14, 2008 | 03:16 AM
GiZzO's Avatar
CLK55 / E350 Coupe
i remember reading in another benz forum rust developing in the area where the pad should be. Maybe a little cushion as well. For #4 to #1 pad i noticed almost 3/4" drop on my 190e
Old Jul 15, 2008 | 07:57 PM
sfclk's Avatar
1999 CLK320
I removed all 4 pads and heard noises from the springs shifting around. You can trim the pads to keep them from rotating.
Old Jul 15, 2008 | 08:00 PM
CLK FAN's Avatar
2000 CLK 3.2
that was because of bad placement...but you are right...you can just trim down the pad just so that it sits in place for the spring to be centered.
Old Jul 15, 2008 | 09:15 PM
ZEEK's Avatar
Yo Momma
i asked the dealer today as well about removing the pads and they said they dont recommend it and if i do remove them then my camber needs to get adjusted or something and will cost more. i dont even know how the pads look like to trim them, i guess ill just put the e class pads.
