steering/suspension pro in Northern VA?
I have been to numerous shops around the area and no one seems to know enough to help me! It's just bugging the heck out of me even though I have learned to live with it so far.
thanks!
Assuming it is not the wheels, make sure your bushings are good (my CLK55 lower control arm bushings were shot at roughly 30K miles). Also, check your dampers (including steering damper).
My shimmy was eliminated after changing the LCA bushings to polyurethane. Good luck.
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWD1V
The ones I received were black.
As far as handling, it helps give you that rock-solid feeling.
I will have to assume at this point that I need to replace my lower control arm bushing, and that polyurethane one on ebay looks like it should be just right. I have all new steering components including control arms, center drag link. I will also get a new steering damper as that needs to be replaced, but i think these things should do it.
I have been going to Mars Automotive for over a year now, he's a great guy and knows his stuff, but going in depth with specific steering/suspension issues isn't always the easiest thing to diagnose unless you do it every day.
Thanks guys i'll post after these are done to see if drive has improved.
But, as they were moving my rear wheels, they noticed my driver side bearings were shot (totally unrelated issue), so I had to dish out about $400 to have that taken care of, talk about labor costs! I don't notice anything major after having it replaced, but I'm all about preventive maintenance. I will go ahead and change the steering damper next to see what that does, should be in soon.
