Only set of Keys Locked in the boot
Old Dec 23, 2012 | 01:16 AM
  #101
AlecTrevelyan's Avatar
2001 CLK320
Pm me please id like to know this as well. I only have 1 set of keys for now.
Old Jan 23, 2013 | 01:15 PM
  #102
edrock200's Avatar
2004 CLK 320 Convert
Another user needing the instructions please. I realize this post seems suspicious as I registered just now (i searched google for "2004 clk 320 locked keys in trunk" and this thread showed up.) Not my car, my girlfriends, but you can find my posts (edrock200) on e46fanatics.com or tivocommunity.com as well. If you need other validation please PM me and I'll give you my phone #.
Old Jan 30, 2013 | 11:34 AM
  #103
2001 CLK320
Bump....can some one pass along some knowledge? I still only have 1 key. I should be getting a spare sometime soon but id still like to know how this is done properly.
Old Jan 30, 2013 | 11:42 AM
  #104
edrock200's Avatar
Found it in another thread:
https://mbworld.org/forums/showthrea...ndria+Mercedes
Here's the main part:
Originally Posted by itsmeek
Usually you have to take the car to MB or call roadside. This procedure (according to roadside from Alexandria Mercedes) is NOT free. It cost me. Anyhow- I watched the tech and this is what he did below:
Just get the doors open then open the fuse console that is along the drivers door on the outside of your dashboard- the door closes on it. Pull out the 4 fuses on the left (7.5 and 5 amps) and then wait a few secs- put them back in and see if the door unlock switch works. If it does- the security system is deactivated and you can use the trunk release to open the trunk. Tech said that if those fuses don't work- pull 4 at a time till you get to the right ones. I tried it in my ml and it worked as well.
TECH MENTIONED THIS WILL WORK FOR ALL NEWER MODELS.
Old Jul 2, 2013 | 07:04 PM
  #105
RobBurton's Avatar
2000 CLK Convertible
This did not work for me on my 2000 clk320 convertible.....ugh!
Old Jul 2, 2013 | 09:48 PM
  #106
RobBurton's Avatar
Does anyone know how to reset the alarm so that the trunk switch will work?
Old Nov 30, 2013 | 02:23 AM
  #107
pilates's Avatar
ML 350
pm me please... I know it's in old thread.
Old Nov 30, 2013 | 02:31 AM
  #108
pilates's Avatar
ML 350
Never mind. I have the solution.
Old Jul 17, 2014 | 06:14 PM
  #109
blagojg's Avatar
CLK 270CDI
procedure for locked key in trunk !
Hi guys, after not find any help on net I find this way by myself. Here it is:
This procedure is for CLK W209 2003-2005 (maybe up to 2009)
1. spread windows (front and rear) with screwdriver.
2. put between windows long metal hard wire with hook so You can open the door via inside handle.
3. Go on back and open the cover of bass speaker, it is behind left head.
4. remove the speaker, it is hold only on plastic stops
5. in holes below speaker You can find line that goes from lever in trunk to back seat holder which unfold seat.
6. pull the wire hard so You can open and fold the back seat.
7. Voala, take the key from the trunk !!!
I hope I helped someone, because I loose a lot of time to find this way by myself !!!
Old Oct 22, 2014 | 08:33 AM
  #110
jockette's Avatar
mercedes c class
mrs sandra farrar
Only set of keyys locked in c class boot how can I access boot to retrieve from back seats please
Old Oct 25, 2014 | 09:42 PM
  #111
oldclk430's Avatar
CLK430
Hi Guys, took my battery out of my CLK430 to jump my excavator on a worksite. Worked a treat. Put the battery on charge for a couple of days as it had been sitting for a while.
Found the boot would not open and the key would not work in the hole. Did not go all the way in so after reading the MB forums used WD 40 and tried to flush the lock. this did not work after hours of trying, and be careful that key can bend really easily. Test it by putting it in a door key hole to make sure it is straight( it should slide straight in).
Was going to put some jumper leads on the + terminal of the starter motor to power the system. I could not guarantee the +battery cable in the boot was not touching the chassis.
One of the posts mentioned the first aid box on the rear parcel shelf to access the boot and it worked( thank you to that post).
Remove the kit and proceed to remove the tray base . I used a blade screwdriver along the edges to free it. there is one circular plug in the middle of the tray. This has a plastic pin trough the centre of it that can be pushed through with a similar diameter item.
Lift the tray out and it will reveal a foam rubber insulation. there are three holes, one in the centre and another on each side. look in either side holes and you will see a black tube about 3-4mm thick(plastic coated metal) . grab this with your hand or pliers.
push toward the rear window and it will release the seat lock so you can access the boot. The boot floor that covers the spare wheel and battery can be lifted out by turning side on and removed through the car.
I was able to put the battery in the boot by going through the car.
If you are not strong enough use jumper leads to reach the terminals so you have power to the car so you can pop the boot(trunk).
The only problem I have now is my windows won't close fully and have abs warning lights on.
At least the car works?
Old Aug 21, 2015 | 07:59 AM
  #112
hass's Avatar
clik 240
Please PM me with the instructions. thanks!!!
would be very greatful if you can pm me the instructions as soon as possible, as i have just got back from hoilday and think i have locked the keys in the boot
thanks in advance
Old Aug 23, 2015 | 05:13 AM
  #113
oldclk430's Avatar
CLK430
Hi Hass,
Hopefully the rest of the car is unlocked and you can access the boot as per the above instructions.
The only other option I would have is to call a locksmith or MB specialist or dealer to unlock the car for you.
Good luck with it all.
Old Aug 24, 2015 | 03:10 AM
  #114
blagojg's Avatar
CLK 270CDI
Ye, I PM Hass, but everything is explained, how to open doors without key (easiest part), and how to open trunk then from inside (hard part)
Old Aug 26, 2015 | 01:49 PM
  #115
prostock's Avatar
c230
PM please
Old Aug 28, 2015 | 08:06 AM
  #116
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
The options I know of to get into the boot trunk:
1 Remove the fuses at the drivers side panel to re-set the alarm.
2 Lift first aid box and use a wire to hook keys.
3 Push in the plastic panel behind arm rest, theres only 2 weak screws hold it at the rear.
4 Remove seat base and then remove seat back bolts at bottom, you can then pull the seat back away slightly to see into the trunk.
5 Remove a speaker.
Theres lots of options, that should get you in and only takes a few mins to do !
Old Aug 28, 2015 | 08:40 AM
  #117
prostock's Avatar
c230
What is "the boot"??
Old Aug 28, 2015 | 08:52 AM
  #118
A1EK's Avatar
It's what some other countries call the trunk outside of America.
Old Aug 28, 2015 | 09:05 AM
  #119
prostock's Avatar
c230
Why would you ever put your keys in there, especially if you only had one? That's what pockets are for.
Old Aug 28, 2015 | 09:16 AM
  #120
A1EK's Avatar
I think your missing the point of this post, as it is cleary not intentialy that people locked their keys in the trunk / boot but by accident.
I myself have done this, it is very easy to do as you can unlock your trunk seperately with the keyfob leaving your doors locked.
I did this with some shopping, my hands were full so unlocked the trunk by holding the keyfob, keys fell into one of the bags, I then shut the trunk and with the doors unlocked the fun then began.
It was snowing at the time and dark.!
Old Aug 29, 2015 | 03:30 PM
  #121
myworld's Avatar
'02 CLK 320 2000 clk320
pm me please!
Old Apr 23, 2022 | 09:54 PM
  #122
tyty430's Avatar
2001 clk 430
Locked my keys in my trunk two days ago I just paid for it to run please help
Originally Posted by TheDon
Good afternoon,
My neighbour managed to lock his only set of keys in his boot this morning as he only used the button to pop the boot wich doesn't unlock the car then shut the boot with the keys still in there.
Within 5 mins or less we gained access to his car wich gave us access to his boot wich gave us access to his keys.
Would it be irresponsible for me to tell you guys how easy it is ? The only reason i ask is i would like to give something back to this community so if you dont mind i would like to tell you how we did it or should i just keep it to myslef.
forums admin....Please let me know if it's ok to post the details (I dont want to get banned from this forum as it is a goldmine when it comes to knowledge)
I can send proof of vehicle if needed, I dropped the keys With my bag before school And I never unlocked the door. Mom payed to get in but no good trunk won’t pop from the power button I’ve been in my car two days trying everything I don’t want to damage her(benzi my whip)
Old Jul 3, 2022 | 06:08 AM
  #123
Tom Merc's Avatar
2010 Mercedes e350 blueefficiency Sport
Done the same
Any suggestions for mine I've left my key in boot?
