Heating fan wont blow!!
Old Nov 27, 2008 | 12:08 AM
rjlawlor646's Avatar
2001 CLK 320
I know there was a thread a while back about this but i cant find it so if anyone has any suggestions let me know..the car hasnt been driven in about 2 weeks and when i got into it, the heat wouldnt blow..tomorow is thanksgiving so i cant even go get a fuse to see if thats the problem..has anyone else had trouble like this?
Old Nov 27, 2008 | 03:29 AM
teemsta's Avatar
CLK W208
*If it turns out not to be the fuse*
I had this problem very recently and it turned out to be the bushes in the fan itself. You can remove the uinit for inspection very easily, using these step by step instructions:
http://mbclub.co.uk/forums/showthread.php?t=3593
If indeed it turns out to be the bushes, I bought these from ebay which did the trick:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=190264088623
Old Nov 27, 2008 | 09:24 AM
gregory13lil's Avatar
2000 CLK430
If it ends up being the heater fan I have one for sale on the link below. I will drop the price to 30 plus shipping.
https://mbworld.org/forums/interior-...or-fanfor.html
Greg
Old Nov 27, 2008 | 09:29 AM
SUNILP's Avatar
2015 E250D
it could also be the fan regulator which controls the fan speed.
Old Nov 27, 2008 | 10:02 AM
hhseouljah's Avatar
2001 CLK 55
agreed with some of the guys uptop.
either the blower motor, or the blower voltage regular. i bought a new voltage regulator and it fixed my problem.
Old Nov 27, 2008 | 12:51 PM
2000 CLK430
My problem ended up being the voltage regulator as well. But, my symptoms were erratic speeds. Sometimes it would speed up on its own or turn off completely after it heated up.
I ended up buying a new fan from Ebay and it still did the same thing. So, I ended up buying the regulator. That fixed the problem perfectly.
I would recommend checking the fuses first and taking the fan off to check for any obstructions first before you buy anything at all. It could be something simple like leaves stuck in the fan. It will only take about 15 minutes to take it off, it is VERY easy to get to from the passenger side.
Greg
Old Nov 27, 2008 | 10:36 PM
2001 CLK 320
thanks for the help, this will be my project for tomorrow..these posts helped alot!!! thanks
Old Nov 29, 2008 | 03:10 PM
2000 CLK430
Did you figure it out??
Old Nov 29, 2008 | 07:36 PM
2001 CLK 320
no not yet...i didnt have time..i tested the fuse in the engine compartment that is labeled ac blower which is fine, is there another fuse i missed? if not then im going to take the blower out and try and figure out whats wrong with it
Old Jan 9, 2009 | 05:52 PM
fspider's Avatar
CL 500 (2003 W215). Range Rover Sport. Ferrari 360 spider. Ferrari F355 spider. MV Agusta F4.
Please accept my apologies for bringing this thread back from the dead. But i have a question if anyone could answer for me. Reading this thread and the how to has been very helpful and i will attempt to remove the blower tomorrow because my erratic fan has now stopped working and boy its cold outside(. Anyway please could some one tell me were the mentioned heater/fan regulator is located so i can check and replace if needed to . Thanks very much in advance.
Old Jan 10, 2009 | 04:22 PM
2000 CLK430
Its located in the passenger side footwell right under the dash. You will have to take the large plastic cover off and then you will see another plastic cover that has a bulge on it. That cover houses the fan and regulator.
Greg
Old Jan 10, 2009 | 05:40 PM
fspider's Avatar
Thank you very much i have now removed and fixed the fan today. Thankyou to the guy who wrote the how to. And thankyou again
Old Jan 11, 2009 | 08:14 AM
2000 CLK430
What ended up being the problem? Leaves in the fan?
Old Jan 11, 2009 | 09:21 AM
fspider's Avatar
No mate. I removed the fan assembly and took out and cleaned the bushes. Put it all back together and it worked great
Old Jan 23, 2010 | 08:07 PM
oldbeaver's Avatar
1993 300D turbo
Fan regulator
Hello,
Can you please tell us where is the fan regulator?
A picture would be magic!
Thank you,
OldBeaver
Greg
Old Jan 23, 2010 | 10:19 PM
2000 CLK430
Originally Posted by oldbeaver
Hello,
Thank you,
OldBeaver
The regulator is mounted right onto the fan, so you cant get it wrong. It is mounted where the bright metal is on the bottom right hand side image.
And this is the regulator:
Hope this helps!! Oh and the fan/regulator are located in the passenger side dash footwell. If you take the cover of the bottom of the dash you will see the fan cover. There should be a DIY on this forum for this.
Greg
Old Jan 24, 2010 | 09:00 AM
oldbeaver's Avatar
1993 300D turbo
Fan regulator
Thank you much Gregory13lil!
Of course your info helps a lot.
Yes, I know there is DIY in this forum for this. However, I cannot see the images there, while I see yours perfectly well.
Tks again,
OldBeaver
Old Jan 24, 2010 | 09:16 AM
2000 CLK430
No problem! I hope you figure it out!!
Greg
